02-24-2012 02:51 PM - edited 03-07-2019 05:10 AM
I have a Perimeter DMZ VLAN that I'm trying to extend to a VM enclosure. The path is:
Perim Sw------->FW---------->Core SW------->Agg SW------------>EnclosureSW---->VM
Cat3350 PIX Cat6509 Cat6509 Cat4948
ON the perimeter switches, the VLAN is 50. This is a /27 network, and the VM in the Enclosure has an IP address for this network.
On the Agg switch, VLAN 50 was assigned to a different network (by a previous engineer), and the Perimeter network is VLAN 53.
So is there a way for me to strip and retag or translate the VM device from VLAN 53 to VLAN 50 and get it extended over to the Perimeter DMZ?
Ray
02-25-2012 06:19 AM
isn't the firewall routing? If so the vlans don't connect between perimeter and core in your diagram.
02-29-2012 04:33 PM
So sorry, I've out ill for a few days. Yes you are correct about the FW doing the routing. My diagram is a bit misleading I think.
It should be this:
I think what I need to do is create another Vlan on the Core sw, let's say 950, and extend it across to the Edge switch. However, I think I have to map VLAN 950 to VLAN 50 at some point, but I'm not sure.
02-25-2012 12:56 PM
In my environment I kept the Perimeter and internal interfaces completely seperate on the VM environment. Do you have a spare interface on your VM enclosure to connect to your 3550?
