SANITY CHECK!
lamav
Level 11
Level 11
Can someone check out this setup carefully and tell me what they think??
I will upload the diagram. Read the detail, please.
Its for a LAN campus environment.
Its just a general architecture/topology drawing. Not too many specifics. Dont need them for now.
What do you think?
ankbhasi
Hi Lamav,
Can you upload the word doc. For some reason .vsd file is not working for me.
May be someone else can provide you with their input.
Ankur
ohassairi
Level 9
Level 9
it is ok
you can also think about using 10G uplink to replace 4x1G uplink if you are rich 🙂
Arkur, I have uploaded the file as a jpeg. It a drawing, not configs.
Ohassairi, thanks. I would probably just use the 10G uplinks on the server farm distro layer to support the heavy traffic of application optimization, server virtualization, SSL offloading, etc...
