SDM KO
nachogdiaz
Community Member
Hello to all, it does a little time I have acquired a shindy 877 but I cannot accede for sdm and it(he,she) is that the alone equipment(team) starts(extracts) even: Would you like to enter the initial configuration dialog? [Yes/no]
If I do not pulsate enter it does not continue. I think that reseteandolo of factory I would solve the problem but I do not know like to do it, someone helps me?
ohassairi
Level 9
Level 9
when you get the message : Would you like to enter the initial configuration dialog? [Yes/no] and you type no. then you get router>. enter enable then show run. please paste your show run
Hello ohassairi, when the question goes out for me, I write NOT, can do the configuration, but on having restarted the equipment this question goes out for me again and I have to answer it with if or not.
The Router since you see, I clean this one.
Would you like to enter the initial configuration dialog? [yes/no]: no
Press RETURN to get started!
*Mar 1 00:00:05.487: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Mar 1 00:00:05.491: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled sslinit fn
*Mar 1 00:00:08.387: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:09.387: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 18:57:32.383: %SYS-5-RESTART: System restarted --
C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4
Router>)T8, RELEASE SOFTWARE (fc3)
Compiled Sat 11-Aug-07 03:34 by khuie
*Mar 1 18:57:32.383: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Mar 1 18:57:32.463: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 1 18:57:32.467: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar 1 18:57:33.955: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
*Mar 1 18:57:33.979: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*Mar 1 18:57:33.983: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*Mar 1 18:57:33.991: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Mar 1 18:57:33.995: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 18:57:34.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
*Mar 1 18:57:34.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to down
*Mar 1 18:57:34.983: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to down
*Mar 1 18:57:34.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to down
*Mar 1 18:57:34.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Router>en
Router#sh run
Building configuration...
Current configuration : 671 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
He does not guard configurations: (
that means some thing is wrong in config register. make show version and paste it. at the end you will find the value of config register. it should be i think 0x2102.
