SDM Prefer
majedalanni
Hi, I have Cisco 2960s with IOS 15, I can't find the command sdm prefer however I can run sh sdm prefer, below is my sh ver and sh sdm prefer!
Please any help how I can get to sdm template, I need to make routing in the switch.
Thanks in advance!
Mike
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(1)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 20-Jul-11 06:32 by prod_rel_team
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
System restarted at 21:13:38 UTC Fri Nov 18 2011
System image file is "flash:/c2960s-universalk9-mz.150-1.SE/c2960s-universalk9-mz.150-1.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24TS-S (PowerPC) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC1523Z50H
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
26 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
sh sdm prefer
The current template is "default" template.
The selected template optimizes the resources in
the switch to support this level of features for
0 routed interfaces and 255 VLANs.
  number of unicast mac addresses:                  8K
  number of IPv4 IGMP groups:                       0.25K
  number of IPv6 multicast groups:                  0.25K
  number of IPv4/MAC qos aces:                      0.375k
  number of IPv4/MAC security aces:                 0.375k
  number of IPv6 policy based routing aces:         0
  number of IPv6 qos aces:                          0
  number of IPv6 security aces:                     0.125k
8 Replies 8
Ivan Shirshin
Are you trying the "sdm prefer" command in config mode? E.g.
     conf t
          sdm prefer lanbase-routing
          end
     wr
     reload
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
There is no such a command!!
when I did ?  its shows
resource                    Configure Resource settings
  rmon                        Remote Monitoring
  sasl                        Configure SASL
  scheduler                   Scheduler parameters
  scripting                   Configure options for scripting languages
  service                     Modify use of network based services
  setup                       Configure setup options
  shell                       Configure shell command
  shutdown                    Shutdown system elements
  snmp                        Modify non engine SNMP parameters
  snmp-server                 Modify SNMP engine parameters
  spanning-tree               Spanning Tree Subsystem
  stackmaker                  Specify stack name and add its member
  stacks                      Configure stacks
  standby                     Global HSRP configuration commands
  system                      Set the system configuration
  table-map                   Configure Table Map
Can you post the output of the show license command? This seems like you're running only a LANLITE license set. For routing support, you need to run LANBASE license set.
Best regards,
Peter
here u go,
sh license
Index 1 Feature: lanbase
        Period left: 0  minute  0  second
Index 2 Feature: lanlite
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
sdm should be in 12.3 and up as I recall, but will try.
Peter was right, you switch is running with lanlite license. You switch model is WS-C2960S-24TS-S, so it should be using lanlite license (lanbase ends with -L).
Catalyst 2960S image ships with universal image and the software image on the   switch is either the LAN base or LAN Lite image, depending on the  switch  model.
And you cannot upgrade it to lanbase.:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-577519.html
Q. Can I upgrade or downgrade a Cisco Catalyst 2960 Series Switch between the LAN Base and LAN Lite images?
A. No. Cisco Catalyst 2960 Series Switches cannot be upgraded from LAN  Lite to LAN Base and cannot be downgraded from LAN Base to LAN Lite.
In other words, the feature set is fixed during manufacture.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
