Secondary ISP connection do not work automatically
pwolsza_wolfik1
I configured on router primary and backup ISP connections.
Everything works fine.
Unfortunately  the automatically switching of the ISP only works when I will put off  the plug from the cisco socket.
When the signal goes down from ISP router, CISCO do not  want to push the traffic into backup ISP.
Tracert gives me information of the destination IP for  example cisco.com but without addresses of hoops.
What to do now ??
If you only want to use primary connection and then use secondary only if primary fails you need to sort out your route-maps.
However main thing you need to do is use IP SLA to keep track of the next-hop for the primary and if that fails then it will fail over to the backup link. Basic IP SLA config -
ip sla monitor 1
type echo protocol ipIcmpEcho
frequency   <-- how often do you want it to check the next-hop
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 10.111.10.225 track 123
ip route  0.0.0.0 0.0.0.0 10.14.10.81 254
the above config will use the tracked route as long as the is responding. If it stops responding then IP SLA will remove the route from the routing table and then the floating static with an AD of 254 will be inserted into the routing table. If the primary next hop comes back up then IP SLA will remove the floating static and insert the tracked route again.
Let me know how you get on and if you have any problems.
Jon
8 Replies 8
Jon Marshall
What are the connections ie how is your router connected to the ISP ? Are they serial connections or ethernet connections ?
Can you post your config ?
Jon
Only fast ethernet connections.
My config:
Current configuration : 7295 bytes
version 12.4
no service  pad
service  tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime  msec localtime show-timezone
service timestamps log datetime msec localtime  show-timezone
service  password-encryption
service sequence-numbers
hostname CISCO
boot-start-marker
boot-end-marker
logging  message-counter syslog
logging buffered 51200
logging console critical
aaa  new-model
aaa  authentication login default local
aaa authorization exec default local
aaa  session-id common
clock timezone Warsaw 1
clock summer-time Warsaw date Mar 30  2003 2:00 Oct 26 2003 3:00
dot11 syslog
no ip source-route
ip dhcp  excluded-address 192.168.2.1 192.168.2.79
ip dhcp excluded-address  192.168.2.151 192.168.2.254
ip dhcp pool ccp-pool1
   import all
   network  192.168.2.0 255.255.255.0
   dns-server 213.134.128.19 213.134.128.20
    default-router 192.168.2.252
   lease 5
ip cef
no ip bootp server
ip name-server 213.134.128.19
ip  name-server 213.134.128.20
ip name-server 194.204.152.34
ip  name-server 194.204.159.1
username xxx privilege 15 secret 5 xxx
crypto  isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto  isakmp key test address 10.192.10.210
crypto ipsec transform-set  ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set  ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to10.192.10.210
set peer 10.192.10.210
set  transform-set ESP-3DES-SHA1
match address 102
crypto map SDM_CMAP_2 1 ipsec-isakmp
set  transform-set ESP-3DES-SHA2
match address 103
archive
log config
  hidekeys
ip tcp  synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface  FastEthernet0
interface  FastEthernet1
interface  FastEthernet2
interface  FastEthernet3
description WAN2
switchport access vlan 2
interface FastEthernet4
description  $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 10.111.10.238 255.255.255.240
no ip  redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip  virtual-reassembly
duplex auto
speed auto
interface  Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address  192.168.2.252 255.255.255.0
no ip redirects
no ip unreachables
no ip  proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface  Vlan2
ip address 10.14.10.82 255.255.255.248
no ip redirects
no ip  unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip  forward-protocol nd
ip http server
ip http access-class 23
ip http  authentication local
ip http secure-server
ip http timeout-policy idle 60 life  86400 requests 10000
ip nat inside source route-map ISP1 interface  FastEthernet4 overload
ip nat inside source route-map ISP2 interface  Vlan2 overload
logging  trap debugging
access-list  1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1  permit 192.168.2.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list  101 deny   ip 192.168.1.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list  101 remark IPSec Rule
access-list 101 deny   ip 192.168.2.0 0.0.0.255  192.168.179.0 0.0.0.255
access-list 101 permit ip 192.168.2.0 0.0.0.255  any
access-list  102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list  102 permit ip 192.168.2.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list  102 permit ip 192.168.1.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list  103 remark CCP_ACL Category=4
access-list 103 remark IPSec Rule
access-list  103 permit ip 192.168.2.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list  105 remark CCP_ACL Category=2
access-list 105 deny   ip 192.168.1.0 0.0.0.255  192.168.179.0 0.0.0.255
access-list 105 remark IPSec Rule
access-list  105 deny   ip 192.168.2.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list  105 permit ip 192.168.2.0 0.0.0.255 any
no cdp run
route-map ISP2 permit 11
match ip address 105
match  interface Vlan2
set ip next-hop 10.14.10.81
route-map ISP1 permit 10
match ip  address 101
match interface FastEthernet4
set ip next-hop 10.111.10.225
line con 0
no modem  enable
transport output telnet
line aux 0
line vty 0 4
transport  input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler  interval 500
end
Okay, couple of things to check.
1) are you currently using both ISPs ie your route-maps suggest you are. If you are then you need to add both next-hops to each route-map because you are not checking the availability of the next hop. So your map matches certain traffic and sends it to a particular ISP but your route-map makes no allowance for that next hop being down.
Can you confirm you are using both ISPs currently with your route maps
2) If the connections are ethernet you may well need to use IP SLA because the ISP next hop could go down but if there is a switch in between your router and the ISP router your router thinks the connection is still up because it's interface is still up/up.
Jon
1) Both ISP are on but I want use only primary and in the case of failure transfer the traffic into backup ISP (lower transfer).
2) Between ISP router and CISCO router is switch indeed. And the connection is up/up.
Putting out the plug change the state of the interface to down and traffic goes through backup ISP.
ip sla monitor 1
Jon
Thanks for suggestions.
I will change the config on Thursday (the next working day) and let you know.
Well on my IOS 12.4(24)T3 the commands are quite different but I managed to configure SLA and now it's working
Many thanks for help !!!
As addition my commands:
ip sla enable reaction-alerts
ip sla 1
icmp-echo 8.8.8.8
ip sla schedule 1 life forever start-time now
track 123 ip sla 1 reachability
One more question, which address is the best as a ping ISP gateway or public address, DNS for example ??
ip sla 1
icmp-echo 8.8.8.8
Glad you got it working. Yes those commands are a bit different, i was using 12.4.
If the ISP gateway works then use that because if in the unlikely event the public DNS server goes down but your ISP gateway stays up then you will shift to the secondary for no reason, whereas if the ISP gateway goes down you know you have lost the link.
Jon
