Secondary SUP CAT 6500
vinoth.kumar
currently we have cat 6506 in our network with single SUP2
now we planned to put secondary SUP on the slot 2
once we inserted secondary SUP2 module with same IOS and model it went to STANDBY COLD state
we configured the primary SUP redunanacy mode as RPR+ and Same as Secondary
but why it says below details
why Operating Redundancy Mode = rpr
Redundant System Information :
Available system uptime = 15 weeks, 5 days, 16 hours, 3 minutes
Switchovers system experienced = 0
Standby failures = 1
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = rpr-plus
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 1
Current Software state = ACTIVE
Uptime in current state = 15 weeks, 5 days, 16 hours, 3 minutes
Image Version = Cisco Internetwork Operating System Software
IOS (tm) s222_rp Software (s222_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF10
a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 19-Sep-07 12:15 by kellythw
BOOT = ,1;disk0:s222-advipservicesk9_wan-mz.122-18.SXF
10a.bin,1;
BOOTLDR = bootflash:c6msfc2-boot-mz.121-8a.EX
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 2
Current Software state = STANDBY COLD
Uptime in current state = 12 hours, 46 minutes
Compiled Fri 13-Jul-07 02:59 by kellythw
10a.bin,1;
Giuseppe Larosa
Hello Vinoth,
my guess is that something has gone wrong in communication between the two supervisors you should try to reset the standby supervisor.
you can also look at log buffer for redundancy messages.
the standby sup could be too slow in coming up and/or it was stopped by active sup.
Hope to help
Giuseppe
thanks for your reply
Yes,
we intially put the secodary SUP and we seen same issue it went ot STANDBY COLD so we removed and tested with the Standby CAT 6500 and found no issue with the IOS and booting image so again we inserted the SUP still the same
Vinoth
