Segmentation of Traffic on Switches
mahesh18
Level 6
Level 6
Hi Everyone,
If we have end device like AP  and their Gateway lives on the Cisco Switch.
But we want that layer 3 gateway of different subnets configured on this switch should not talk to each other for that can we config the acl and apply that to the layer 3 vlan on the switch.?
or
If we have switch and it has default gateway for each different subnets on the switch and we have no ACL on the switch can then IP in one subnet talk to IP in another subnet?
Mahesh
2 Accepted Solutions
Hi Mahesh,
I mean users on vlan 10 can access the 10.10.0.0/16 network as we have static route there?
Correct, assuming network 10.10.0.0/16 is up and running. Also, for reachability, the device that has network 10.10.0.0/16 needs to have a static route back to vlan 10 (192.168.10.0).
Also they can access any network as we have default gateway configured?
In an environment like this where we have multiple SVIs and the switch is actually routing, it is better to have a default route instead of a default gateway.  A default gateway is mainly used on a layer-2 switch with one SVI which is used for management and needs reachability to the rest of the network.
So,
ip route 0.0.0.0 0.0.0.0 <next hop ip>
Hi Mahes
If say switch1 has default route to switch2 then if device in vlan 10 can access the rest of network as
switch1 has default route to switch 2 right?
Correct.
Also to make this happen then switch2 needs route back to device in vlan 10 right?
That is correct.
7 Replies 7
Reza Sharifi
Hi Mahesh,
That is correct. You would need to configure ACLs and apply them to proper vlan interfaces (SVIs) to block communications.
Correct. By default, the SVIs can communicate with each other unless you configure access lists and applies them to the SVIs.
Hi Reza,
Thanks for answering this question too.
One last thing if we have this setup
Different  subnets and all the layer 3 gateway  for those subnets live on one switch.
There are no ACL  so all these layer 3 subnets can talk to each other.
If we have these  layer 3 SVI  on the switch
192.168.10.1  vlan 10
192.168.20.1  vlan 20
192.168.30.1 vlan 30
If we have this static routes on the switch
10.10.0.0/16 next hop 10.1.10.0
default gateway is 0.0.0.0/0
then users on the vlan 10 can access all the ips in the vlan 20 and 30 and also they can access  any
network as long as there is static route on the switch ?
Mahesh
Hi Mahesh,
So,
Hi Reza,
sorry for typo
i mean to ask for
ip route 0.0.0.0/0 not ip default gateway.
Mahesh
Hi Mahes
Correct.
That is correct.
Many thanks Reza!!!
Best Regards
Mahesh
AymanMunassar
Q1: Yes, Assuming you enabled the routing between them
Q2: No, unless you type (config)# ip routing in the L3 switch
