Showing results forĀ
Search instead forĀ
Did you mean:Ā
Selective Q-in-Q in Nexus 93180yc-ex
CSCO11070817
We are trying to configure selective QinQ according to Nexus 9300 configuration guide in a nexus 93180yc-ex, however the following command is not supported:
switch(config-if)# switchport vlan mapping <inner_tag> dot1q-tunnel <outer_tag>
Why is this so if in release notes appears the following:
The following features are not supported for the Cisco Nexus 9200 Series switches and the Cisco Nexus 93108TC-EX and 93180YC-EX switches:
  • Layer 2 Q-in-Q, due to a hardware limitation (supported for Cisco Nexus 93108TC-EX and 93180YC-EX switches but not for Cisco Nexus 9200 Series switches)
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/release/notes/70342_nxos_rn.html#_Toc456959033
Any help?? Thanks in advance
Here I attach config guide link:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_01101...
CSCO11070817
Solved upgrading to 7.0(3)I5(2) nx-os version (released a week ago)
Current version does not support it: 7.0.3.I4.2
