set base IOS - Help
ilana_ilana
Hello all,
For core switch migration from old 6506 (running old set base IOS) to 6807, I have to create point to point layer 3 interfaces between both.
I have configured ip address in 6807 gig interface, but I don't know how to configure it in set base IOS. Can any help please ?
Also the old core switch is keep notifying following msgs, can any help  how to stop them ?
016 Oct 23 02:13:44 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:13:47 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
2016 Oct 23 02:13:47 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:13:49 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
2016 Oct 23 02:13:50 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:13:52 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
2016 Oct 23 02:13:53 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:13:55 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
2016 Oct 23 02:13:56 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:13:58 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
2016 Oct 23 02:13:58 PDT -07:00 %SYS-2-FAN_NFAIL:Fan 1 failed
2016 Oct 23 02:14:01 PDT -07:00 %SYS-2-FAN_NOK:Fan 1 okay
7 Replies 7
use the set command to configure the IP address:
http://www.cisco.com/en/US/products/hw/switches/ps679/products_command_reference_chapter09186a00800d9f4d.html#4132
The fan error messages can be turned off by, as far as I remember, by changing the logging level:
6506(config)#logging console critical
Thank Gpauwen,
I been through this link before & it showed procedure to SC0 (management interface) and SC1 (Serial interface) not the physical interface. I have to configure physical interface as layer 3, for example in current IOS we configure l3 interface as:
interface gig 1/1/1
no switchport
ip address 10.0.0.1 255.255.255.0
no shutdown
I want to configure same above in set base IOS switch, to have point to point connectivity & configure static route to point the next hop.
Any suggestions ?
Thank
From following link:
http://www.fryguy.net/2011/08/15/catos-and-ios/
"So, what is this thing called CatOS one might ask.  Well, in short it is Cisco OS that is Layer 2 only; there are no routed interfaces, no IP addresses on interfaces (well, there is SC0) or IPs for VLANS – just L2 VLANS and Ports."
If there's no way to interconnect CatOS with IOS base switch via Layer 3, what alternate options we have.
If both connected using Layer 2 then we have to be careful about STP calculation. 6807 (IOS base switch) should have high priority so that it won't be part of STP calculations.
You can still trunk CatOS and IOS switches, only the Layer 3 needs to be done on an IOS module or switch:
https://supportforums.cisco.com/document/11936/how-configure-trunking-between-cisco-catalyst-switches-run-catos-and-cisco-ios-system
Sorry for the misunderstanding. For anything layer 3 related, you need either an MSFC, and that actually runs IOS. Does your 6506 have that module installed ? You cannot assign IP addresses to interfaces in CatOS (other than management addresses).
Unfortunately we don't have MSFC.
So did we left with trunking option to interconnect only ?
Indeed, trunking is the only option left...
