set BAUD 9600 error - vb:: no such device
ed.bonnell
2960 switch: To speed up XMODEM, I changed the console port speed to 115200, but did not set it back to 9600 right away. Now I cannot. The console port is stuck at 115200. I boot into bootloader mode (switch: prompt) and can see the commands, but when I type set BAUD 9600, I get vb:: no such device. I had just upgraded the IOS to current. I have tried resetting the switch, nothing works.
amritpatek
Level 6
Level 6
This warning message always appears when we change Mirage baud rate at the boot loader prompt after a baud rate change recovery by issuing password-reset CLI. This is considered as minor issue but needs to be fixed since the user sees it every time doing baud rate
Lubo1
Try this:
1. boot to ROMMON
2. flash_init + load_helper
3. set_bs bs: rw ...sets read-write attribute to boot sector
4. unset BAUD
5. flash_init
6. set_param ...saves parameters to memory
7. set_bs bs: ro ...sets boot sector back to read-only
8. boot
Lubomir
Regarding:
Aug 10, 2009 9:02 AM (in response to ed.bonnell)
Re: set BAUD 9600 error - vb:: no such device
Try this:
1. boot to ROMMON
4. unset BAUD
5. flash_init
8. boot
Lubomir
These steps from Lubomir worked for resetting the baud rate back to 9600 on a switch that kept going back to 115200 baud not matter what was done.
TRIED -> The running-config was modify to not have "speed 115200".
TRIED -> Went into ROMMON  and did the "unset BAUD" and this appeared to keep the 9600 baud after the "boot", but as soon as a "reload" was done the 115200 baud was back in the running-config and the ROMMON "set" results.
It was not until the steps above from Lubomir in which the flash_init and set_param etc were done that the switch kept the 9600 baud after a "reload"
Thank you for the help
One other thing to mention is that the BAUD command is case sensitive. The first time I tried this I was using "baud" in lower case, which did not work.
Thank you, Lubomir!
