Setting a Static IP for a Computer
desai.shukla
I have a Cisco RV082 Dual WAN VPN Router, and I'd like to create a static route for one of the computers. Any ideas on how to do this?
Ganesh Hariharan
In the RV082 go to Setup -> Advanced Routing, and define a static route: destination IP and mask (as needed for one or a range of machines on the other side of the Intranet), default gateway is the LAN IP of your RV082, hop count 1, interface is LAN.  Save settings.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
I believe this article might help further explain the needed configuration.
http://www6.nohold.net/CiscoSB/Login.aspx?login=1&pid=4&app=search&vw=1&articleid=585
Alex
