Setting up a learning lab with errors
larryb8207
Hi all,
Hope everyone is doing well. I am currently setting up a home lab environment and have run into a bit of an issue and I am trying to wrap my head around it. Basically the setup is NetworkPlaying.png and I can ping from the wireless laptop to the interface 0/1 on the 1841 but not to 192.168.1.1 or any of the servers on the 192.168.1.0/24 subnet. I am also trying to pass internet traffic to this subnet with no success. So I have beat my head against the wall and that didn't help(just left a nasty oil spot on the wall....) Here is the config for the 1841:
version 12.3
hostname Parasite
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.10.1 10.1.10.99
ip dhcp pool WireLessPool
   network 10.1.10.0 255.255.255.0
   default-router 10.1.10.1 255.255.255.0
   domain-name LarrysLab.local
no ip ips deny-action ips-interface
no ip domain lookup
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
ip address 10.1.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
ip classless
no ip http server
no ip http secure-server
control-plane
alias exec s show ip int br
alias exec sr show run
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
I am probably screwing this all up, but it's a learning day and I will destroy this many times before the day is out. Thanks for your help.
22 Replies 22
Reza Sharifi
can you put an IP address on interface 0/1?
duplex auto
speed auto
And see if you can ping it from the wireless laptop.
Thanks for the quick reply Reza! If I do that will it also conflict with the 192.168.1.1 address from the first linksys wireless router? I will do that but I feel as if it might be a conflict. Thanks again Reza!
Larry,
My apologies.  I did not see that 1.1 was assigned to linksys.  Make the 1841 interface 1.100 please.
Reza,
It has been set to manual 1.100. Lost my internet connection due to conflict with 1.1
Ok, so what was the IP address when you used DHCP?  I thought, your diagram shows it is 1.100
If you change it back to DHCP, can you do sh ip arp and see what IP the DHCP assigned to 0/1?
When I used dhcp it also assigned .100
Internet  10.1.10.1               -   0012.7f7e.fab0  ARPA   FastEthernet0/0
Internet  192.168.1.104          16   0026.f276.b9d0  ARPA   FastEthernet0/1
Internet  192.168.1.107          16   0050.8dcb.a9ee  ARPA   FastEthernet0/1
Internet  192.168.1.101           0   6cf0.4908.0aa6  ARPA   FastEthernet0/1
Internet  192.168.1.100           -   0012.7f7e.fab1  ARPA   FastEthernet0/1
Internet  10.1.10.101            13   0017.f24b.ba4a  ARPA   FastEthernet0/0
Internet  10.1.10.100            57   0018.39b5.3970  ARPA   FastEthernet0/0
Internet  192.168.1.1            16   0021.29d9.827a  ARPA   FastEthernet0/1
Ok, when you are logged in to the 1841, can you ping the linksys (1.1) or 101 or any of the servers in this subnet?
yes I can. I think it could be an ip route issue.
1841 is a router and by default IP routing is enable, but to be sure can you try enabling it one more time?
It has been enabled.
Parasite#sho ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.10.0 is directly connected, FastEthernet0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/1
Here are the tests from pinging from the source of 0/0
Parasite#ping 192.168.1.1 source 10.1.10.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.10.1
Success rate is 0 percent (0/5)
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Thanks Reza.
These are good tests.
Can you post sh ver
Here you go Reza,
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.3(14)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 11-Jul-05 21:04 by ccai
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Parasite uptime is 3 hours, 52 minutes
System image file is "flash:c1841-advsecurityk9-mz.123-14.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 4.1) with 110592K/20480K bytes of memory.
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2142 (will be 0x2102 at next reload)
Larry,
The config register needs to be 0x2102
Can you reboot and test again?
Reza
