Setting up a learning lab with errors
larryb8207
Hi all,
Hope everyone is doing well. I am currently setting up a home lab environment and have run into a bit of an issue and I am trying to wrap my head around it. Basically the setup is NetworkPlaying.png and I can ping from the wireless laptop to the interface 0/1 on the 1841 but not to 192.168.1.1 or any of the servers on the 192.168.1.0/24 subnet. I am also trying to pass internet traffic to this subnet with no success. So I have beat my head against the wall and that didn't help(just left a nasty oil spot on the wall....) Here is the config for the 1841:
version 12.3
hostname Parasite
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.10.1 10.1.10.99
ip dhcp pool WireLessPool
   network 10.1.10.0 255.255.255.0
   default-router 10.1.10.1 255.255.255.0
   domain-name LarrysLab.local
no ip ips deny-action ips-interface
no ip domain lookup
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
ip address 10.1.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
ip classless
no ip http server
no ip http secure-server
control-plane
alias exec s show ip int br
alias exec sr show run
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
I am probably screwing this all up, but it's a learning day and I will destroy this many times before the day is out. Thanks for your help.
22 Replies 22
Reza,
I have changed the register and rebooted, now I cannot ping 4.2.2.2?
-Larry
ok how about this test again
Parasite#ping 192.168.1.1 source 10.1.10.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.10.1
Success rate is 0 percent (0/5)
If good, how about pinging a server from the wireless laptop?
Reza,
ok, I changed the interface 0/1 to dhcp and now I can ping 4.2.2.2 but still cannot ping 192.168.1.1 source 10.1.10.1
-Larry
Larry,
how about from the laptop?
Can the servers ping 192.168.1.1?
Do the servers have default gateway?
Hey Reza,
The servers have a default gateway of 192.168.1.1 and they can ping it and communicate with the internet just fine, the laptop(10.1.10.101/24) cannot ping 192.168.1.1/24 or communicate with the internet.
Thanks Reza.
-Larry
Can you add a default route to the router
ip route 0.0.0.0 0.0.0.0 192.168.1.1 (linksys)
can the servers also ping 192.168.1.100 (1841 interface)?
Route added
The servers can ping the interface 192.168.1.100.
Here are a few test after adding the requested route.
Parasite#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/11/16 ms
Parasite#ping 4.2.2.2 source 10.1.10.1
Parasite#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.10.0 is directly connected, FastEthernet0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/1
S*   0.0.0.0/0 [1/0] via 192.168.1.1
Larry
Ok so...
Success rate is 80 percent (4/5), round-trip min/avg/max = 8/10/12 ms
No I can ping from the subnet 192.168.1.0 to 10.1.10.0. THIS was due to a misconfiguration in the main router coming off of the internet and it not having the correct static routing setup. My mistake and sorry we wasted time troubleshooting the wrong device.
Now, if I could only get the internet working on the laptop(10.1.10.101)
Thanks for all your help and time so far with this Reza.
-Larry
