Setting Up Etherchannel
cdouglas
Here is the situation 1 server, 2 nics and 2 3500XL series switxhes. I would like to set up an etherchannel for the server. I have read on cisco's web site that etherchannel cannot be set uo on 2 switches using a gigastack. Is it still possibe to set this up on these switches or do i need to go to 3550 switches.
2 Accepted Solutions
You can connect them to different switches on each stack, but it would not be an etherchannel, you'd have one active, and one standby connection. You'd also want to ensure that the PC does not bridge between the two links, or you'd wind up with a layer 2 loop. This applies whether you have 3500xl switches or 3550s.
The only platform that supports etherchannel across multiple switches in a stack is the 3750 series.
HTH,
Bobby
*Please rate helpful posts.
That is correct.
HTH,
Bobby
9 Replies 9
Bobby Thekkekandam
Do your NICs support teaming? If so, then simply configure the NICs as a team, and configure the 3500xl ports as an etherchannel as documented here:
http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a00800d9d3d.html#xtocid15
Keep in mind thata the 3500xl switches do not support 802.3ad, so you must disable negotiation on your NICs.
HTH,
Bobby
will this method still work on 2 3500xl switches? Yes the nics do support teaming but I would rather a switch solution. I do have 2 3550 series switches that can be swapped out to support if that is the only option for this set up if neccessary.
HTH,
Bobby
Thanks for your prompt reply. So in this set up load balancing is not an option just port redundancy.
That is correct.
HTH,
Bobby
My case is related so pls. allow me to join. I configured two ports in a L2-etherchannel. Both ports are up-up but I donot know why status 'I' is shown for both ports involved.
to0#show etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
Number of channel-groups in use: 6
Number of aggregators: 6
Group Port-channel Protocol Ports
5 Po5(SD) PAgP Gi6/5(I) Gi7/5(I)
also: in the following, whats the meaning of 'Port state = Up Sngl-port-Bndl Mstr Not-in-Bndl' ??
to0#sho etherchannel 5 det
Group state = L2
Ports: 2 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: PAgP
Ports in the group:
Port: Gi6/5
Channel group = 5 Mode = Desirable-Sl Gcchange = 0
Port-channel = null GC = 0x00050001 Pseudo port-channel = Po5
Port index = 0 Load = 0x00 Protocol = PAgP
Flags: S - Device is sending Slow hello. C - Device is in Consistent state.
A - Device is in Auto mode. P - Device learns on physical port.
d - PAgP is down.
Timers: H - Hello timer is running. Q - Quit timer is running.
S - Switching timer is running. I - Interface timer is running.
Local information:
Hello Partner PAgP Learning Group
Port Flags State Timers Interval Count Priority Method Ifindex
Gi6/5 U4/S4 30s 0 128 Any 0
Age of the port in the current state: 13d:12h:46m:50s
Port: Gi7/5
d - PAgP is down.
Local information:
Gi7/5 U4/S4 30s 0 128 Any 0
Age of the port in the current state: 13d:12h:51m:39s
Port-channels in the group:
Port-channel: Po5
Age of the Port-channel = 37d:21h:02m:23s
Logical slot/port = 14/4 Number of ports = 0
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Not-Inuse
Protocol = PAgP
can you post the configs of the channel from both sides ?
GNT
The etherchannel is for connecting one server. Server NICs are 'team'ed.
Here is the config of ports in the etherchannel:
interface GigabitEthernet6/5
description TOR DC& FP
no ip address
switchport
switchport access vlan 22
switchport mode access
spanning-tree portfast
channel-group 5 mode desirable
interface GigabitEthernet7/5
description TORB DC& FP
no ip address
switchport
thanks for your help,
Ah, I believe I see the problem. Since you are creating an etherchannel from the switch to a server with NIC teaming, using mode "desirable" will not work. "desirable" mode negotiates the channel with the channel partner using PAgP, which is a cisco proprietary protocol. Since the Server NIC does not understand the PAgP frames, the channel is not properly negotiated.
There are two ways around this. The preferred way is if the server and the switch (depending on your platform and IOS version) supports 802.3ad, you can use channel-group mode mode active, which is the IEEE equivalent of mode 'desirable.'
Secondly, if one or both of the devices do not support 802.3ad, then you can use channel group mode on, on the switch, which will disable negotiation of the channel and forces the LAN ports to channel unconditionally.
HTH,
Bobby
