Setting up NAT with firewall behind router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-19-2016 05:16 AM - edited 03-08-2019 07:04 AM
Hello all,
I am just learning the basics of ASA configuration.
I have seen many people state that it is better to have the ASA sit behind a router instead of on the edge.
In this scenario, would I configure NAT to access the internet on the ASA or would I do it on the edge router?
I am also looking to set up a site to site VPN tunnel usinf IPSec over GRE. Would this be done on the ASA or the router in this setup.
So far I have learn't to do the above on routers. They seem fairly straight forward to configure on the ASA I am just not sure how it is affected by having a router after the firewall.
Appreciate any advice.
Matt
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2016 05:56 AM
For NAT, a rule of thumb is that it's implemented on the device that has the public IP address(es) on the outside interface and a private IP on the inside. If this is your setup:
Internet ----- (Pu) - Router - (Pr) ----- (Pr) - ASA - (Pr) ---- internal Network
Here the NAT is typically done on the router.
In many cases this router is removed from the network if the ISP provides an Ethernet-Link:
Internet ----- (Pu) - ASA - (Pr) ---- internal Network
Now NAT is done on the ASA.
For your VPN-needs, The ASA doesn't support IPsec/GRE, that can only be done on the router. In many cases I would configure that the following way:
/ ----- (Pu) - ASA - (Pr) ---- internal Network
Internet- SW |
\ ----- (Pu) - Router
Both ASA and router is connected to the Internet, but the VPN-traffic is sent again through the firewall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2016 06:05 AM
Thank you Karsten,
That is very helpful.
Is it more common to configure site-to-site VPN's on the router or is there a better way to configure this on the ASA?
Also in your final topology where you have the internet connected to the router and the router going via the ASA, would you configure the VPN access list on just the ASA or both?
Matt
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2016 06:16 AM
The (IOS) router has much more features for site-to-site VPN than the ASA. But if you don't have many VPN peers, then the ASA is often "good enough".
The Access-Control can be done on the router or on the ASA. In a pure hub-and-spoke topology I would configure it on the ASA, but if there is spoke-to-spoke communication it has to be done on the VPN-Router or even on the branch-routers.
