07-07-2005 11:57 AM - edited 03-05-2019 11:34 AM
Hey all - I set up a lab to mess around with at home. The switch is an ancient dinosaur, but still it gives me something to mess with.
Does the 1900 xswitch support a reverse telnet port? Anything I need to be aware of in configuring the line? I can telnet to the management port on the switch. I can attach a console cable and connect to the console port. I tried setting up a 2509 router with an Octal cable for access. It works for reverse telnet to my other Cisco routers, but I get "% Connection refused by remote host" when I try reverse telnet to the switch.
Help!
07-07-2005 01:29 PM
I assume that you have verified the settings for the port on the 1900 (9600/8/n/1) ?
Try to find the line where the 1900 is conected to with the ´show line´ exec command and then manually clear the line with the ´clear line x´ command...
HTH,
GP
07-07-2005 03:30 PM
Thanks for the info. I verified the line:
Swi1900-A#sh line
RS-232 configuration:
9600 baud, 8 data bits, 1 stop bits, None parity
Autobaud: Enabled
Modem dialin: Enabled
Idle time-out: 0
Modem Init String:
Silent time: 0
Password Threshold: 3
I know on the routers I needed to configure login. I don't see that option when configuring console on the 1900.
1900 line options:
Swi1900-A(config)#line cons
Swi1900-A(config-line)#?
Line configuration commands:
autobaud Match remote baud-rate
databits Set number of data bits per character
exit Exit from line configuration mode
help Description of the interactive help system
modem Configure the modem control lines
no Negate a command or set its defaults
parity Set terminal parity
password-thresh Configure the maximum password threshold
silent-time Configure the silent time on login intrusion
speed Set transmit and receive speeds
stopbits Set asynch line stop bits
time-out Configure the line idle time-out period
The switch is running pretty ancient IOS. Do you know off-hand if I would need to configure login on the console port, and if that option is available on more recent IOS? I'm running:
Cisco Catalyst 1900/2820 Enterprise Edition Software
Version V9.00.05
Copyright (c) Cisco Systems, Inc. 1993-1999
Swi1900-A uptime is 1day(s) 08hour(s) 45minute(s) 07second(s)
cisco Catalyst 1900 (486sxl) processor with 2048K/1024K bytes of memory
Hardware board revision is 5
Upgrade Status: No upgrade currently in progress.
Config File Status: No configuration upload/download is in progress
15 Fixed Ethernet/IEEE 802.3 interface(s)
Base Ethernet Address: 00-04-27-A8-3E-80
07-07-2005 08:09 PM
And the solution is!
I did not disconnect previous sessions after starting a reverse telnet session. I figured that out by using an unused connection from my 2509. Worked fine. Tried again, wouldn't connect. Moved to a different line. Worked fine for the first session. Wouldn't reconnect.
I forgot to jump back to the 2509 and disconnect the line. Oh well, it's working now. User error.
