setting up VLAN with 802.1p
vikaschndr
I am new to switch configuration.
I am trying to setup QoS on the 3560 switch with CoS (802.1p)
I would be running some devices which would send traffic with CoS marking (this is the changes I have done and would like to test the code changes done)
I am able to create twl VLAN 20, and 30
I have allocated port 5 to 12 to VLAN 30 and
13 to 24 to VLAN 20, I have also enabled 'mls qos trust cos' for all the ports.
I have also run 'ip routing'
now on the devices (linux machines) I have assinged eth0 to 192.168.20.10 and other device to 20.11 with VLAN as 20.101 and 20.102 resp.
on the other device I have eth0 to 192.168.30.10 and 30.11 with VLAN as 30.101 and 30.102 resp
from the switch I can ping eth0 interface of the device but not the VLAN interface, since CoS would be on the VLAN interface that is what I need to work.
I also tried to configure all the ports to 20 and 30 VLAN togather so that I cna keep VLAN on one subnet say .30 and eth0 on one say .20
but I am not able to allocate same ports to two different VLAN's.
I am reading thru articale and configuring the switch as what I understood as I have not done this before, please bare with me.
any help would be appreciated.
my current config :
ip subnet-zero
ip routing
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 30
switchport mode access
switchport voice vlan 30
switchport priority extend trust
mls qos trust cos
spanning-tree portfast
interface FastEthernet0/6
mls qos trust cos
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
mls qos cos override
macro description cisco-desktop
spanning-tree bpduguard enable
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 20
mls qos trust cos
interface FastEthernet0/14
mls qos trust cos
interface FastEthernet0/15
mls qos trust cos
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 148.147.179.172 255.255.255.0
shutdown
interface Vlan20
description for 20
ip address 192.168.20.1 255.255.255.0
priority-group 4
interface Vlan30
description 30 subnet
ip address 192.168.30.1 255.255.255.0
ip default-gateway 148.147.179.1
ip classless
ip http server
control-plane
banner login ^CC
Warnning
this is a Cisco
line con 0
exec-timeout 0 0
logging synchronous
login
line vty 0 4
password XXX
login
line vty 5 15
password XXX
login
end
Jose Solano
Level 4
Level 4
An access port belongs to and carries the traffic of only one VLAN (unless it is configured as a voice VLAN port). Traffic is received and sent in native formats with no VLAN tagging. Traffic arriving on an access port is assumed to belong to the VLAN assigned to the port.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swint.html#wp1107751
Hope this helps.
Hi Leo,
Thanks for the reply.
I have configured with voice vlan and access, with this I can assign two different subnets on the same port(two VLAN's)
now my routing is working perfectly.
I just have a single issue now, I want to change the DSCP marking based on a particular CoS (802.1p) 4, but the DSCP marking is not changing.
I am trusting CoS in my setup.
