Setting Virtual Terminal Password?
kmphilbin
When I was configuring a set of Cisco C3750 network switches (firmware version: 12.2(25)SEB4), I apparently incorrectly entered my Virtual Terminal Password. It is not causing a problem, other than I do not get prompted for a password when I telnet into the switch.
I haven't been able to find a command in the Command Reference book that allows me to reset, or turn on this feature.
Other than starting from scratch and reconfiguring the switches, is there a command, or set of commands, that would allow me to prompt for a password when someone telnets into the switch?
I appreciate all suggestions.
Kevin
Hi Kevin,
Switch# config Term
#line vty 0 4
#password cisco
#login
#end
#write mem
the above example will set the telnet password to cisco.
Shaheen
7 Replies 7
Hi Kevin,
Switch# config Term
#line vty 0 4
#password cisco
#login
#end
#write mem
Shaheen
Shaneen,
Excellent. That worked perfectly.
I suspected it was a line command. I am not well versed in them and was not really willing to poke around, unless rebuilding the switch was my only option.
Thanks for the help.
Sincerely,
Kevin
Kevin,
I assume you are talking about the VTY password. Entering the incorrect password shouldn't be the reason why the switch isn't prompting for a password. Rather, line vty 0 4 might be configured with 'no login' and this would cause the router to bypass login to access user mode. If it is then configure 'login' under 'line vty 0 4' mode to be authenticated.
Sundar
Sundar,
Shaheen posted the same fix with a nice little script about 3 minutes before you did.
Sincerely,
Kevin
Hi Sundar,
I saw in all respnses the same command, why VTY must be in line vty 0 4, could be other options?
yes depending on platform as example you can have many lines , generally people use 0 - 4 and 0 -15
from a 3900 router
sh line vty ?
<0-858> First Line range
from an ASR 1000X
(config)#line vty ?
<0-97> First Line number
3600 switch
#line vty ?
<0-15> First Line number
millerlae
Kevin-
You'll have to do this from Console since you don't know your VTY password
1. Enter config t
2. Enter int vty 0 4
3. Type password
4. Type login
5. Type Control Z
6. type copy run star (to save configuration)
