SF300-24 DHCP Server not responding (worked once but not again)
dcsutherland
Tried to get the new firmware DHCP Server option working but after turning it off and back on it doesn't seem to give any addresses anymore.
Anyone else having troubles or success actually using the SF300 v1.4 DHCP Server?
I even tried factory default reset but no luck.
When I did have it working everything was good but the older Cisco Meraki would not get an IP address so I had to revert to an older DHCP server.  When I tried again today by turning the older server off and the SF300 back on, none of the Windows machines that previously would work would get an address.
Am running:
L2 Mode
SF300-24 24-Port 10/100 Managed Switch
 Edit
 Edit
switche2653dEdit
1.3.6.1.4.1.9.6.1.82.24.1
0 day(s), 0 hr(s), 37 min(s) and 28 sec(s)
00:25:84:e2:xx:xx
Disabled
Software Information
1.4.0.88
66ab3618cb29023da5ce7c2177e6c3d4
1.3.7.18
1f59c2af2f50786e1a8a3146de42c867
1.3.5.06
da44c9c583e5a8a274f911c4d16f501e
en-US
1.4.0.88
N/A
Edit
Enabled
Enabled
Disabled
Disabled
Disabled
0 Replies 0
