SF300-24P / Maintain Power Signature
Dear Sir,
Model: SF300-24P 24-Port 10/100 PoE Managed Switch with Gigabit Uplinks:
What is minimum load to be provided, to fulfill the MPS (maintain power signature of POE)?
Rgds.
pieterh
not to be found on the Cisco site, not even in PoE troubleshooting guide a minimum is mentioned, but not the value!
as this post at het Texas Instruments site it may be 10mA
To clarify, did you attach this 1kohm resistor to the output of the PD (VDD-RTN) or on the output of the converter? You will need to reduce the resistor value until 10mA is the input current draw.
