SF300 - How to add source VLAN tags to VLAN Mirroring?
keithhesstx
I have an SF300-24 in L2 mode split into 4 VLANs.  All the FE ports are configured as Access Ports on their respective VLANs.  No trunk ports.  No tagging on the connected traffic.  I have the 4 VLANs Mirroring to one of the gigabit ports, GE4, where I have Wireshark running to monitor traffic.  So far, so good.  However, I'd like the source VLAN ID inserted into the mirrored traffic so that it's easier for me to fetter out which VLAN the traffic came from.  Can that be configured on the SF300?
Seems like something RSPAN would do, but that doesn't show as an option on the SF300.  Running latest firmware.
pieterh
If you are source is VLAN's not ports then it should be sufficient to configure your monitor port GE4 as a vlan-trunk port.
packets will be sent out to GE4 as vlan-tagged packets with the source vlan in the vlan tag.
NB! normal workstation NIC drivers are not vlan aware,
So in addition you may need to tweak your wireshark setup to NOT ignore/strip the vlan tag
see the wireshark wiki
