SFP-10G-T-X= Compatibility with C3850-24XS
alejandro_pardo
A client has a switch C3850-24XS and I did not found documentation of compatibility with SFP-10G-T-X=, maybe because the SFP+ is a recent product.
Can somebody help me to confirm if SFP-10G-T-X= works with C3850-24XS Switch?
Thanks for your support.
5 Replies 5
Reza Sharifi
Are you sure that is the correct part number for the SFP+?
See the compatibility list for all the supported 10Gig SFP+s
https://tmgmatrix.cisco.com/?si=C3850-24XS
I found this Updated:September 27, 2021 https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/q-and-a-c67-743938.html
Does not exist mention about C3850 family, I think because are old swiches...
Have a look at table-12 and see the supported optics:
●  1000BASE-T ports: RJ-45 connectors, 4-pair Cat-5E UTP cabling
●  Multigig-T ports: RJ-45 connectors, 4-pair Cat-5E, Cat-6, Cat6A UTP cabling
●  1000BASE-T SFP-based ports: RJ-45 connectors, 4-pair Cat-5E UTP cabling
●  100BASE-FX, 1000BASE-SX, -LX/LH, -ZX, -BX10, DWDM and CWDM SFP transceivers: LC fiber connectors (single-mode or multimode fiber)
●  10GBASE-SR, LR, LRM, ER, ZR, DWDM SFP+ transceivers: LC fiber connectors (single-mode or
multimode fiber)
ammahend
here is the compatabikity matrix, dont see 3850 in the list. https://tmgmatrix.cisco.com/83fb74d3-7c27-4617-9178-28109acee749
for future reference you can use this link
https://tmgmatrix.cisco.com/?tpid=961
-hope this helps-
Leo Laohoo
Depends on the firmware of the switch.
I have seen some people deploy non-Cisco branded SFP-10G-T re-flashed as GLC-T/GLC-TE but they support 10 Gbps copper.
