Sfp compatibility between finisar and Cisco.
gulzar.shaikh
currently we have nutanix servers with finisar Sfp it’s a multi mode Sfp and it’s shall be connected to Cisco switch 9200 10 g SR.I gave the command service and error disable but still port is not coming up between switch and server kindly suggest how to make the port up
M02@rt37
Hello @gulzar.shaikh ,
what is the IOS version of the C9200.
Please check the compatibility matrix here:
https://tmgmatrix.cisco.com/?npf=341
Best regards
Leo Laohoo
First, does the 9200 support 10 Gbps optics?
Next, if the 9200 has a 10 Gbps optics attached, is the optics in the Nutanix server a 10 Gbps optics as well?
Finally, are both optics have the same wavelength?
