SFP compatibility with Switch C3650-24PS-E
I need to know if the transceiver module GLC-LH-SMD is also compatible with this switch, because in the compatibility table the SFP assigned is GLC-LH-SM
This link is very useful:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc476298520
Your SFP is compatible, remember to use the same SFP on both ends to avoid any inconvenience.
Catalyst 3600 Series Switches Support
Network Device
Transceiver Module
Minimum Software Release Required
DOM Support
Cisco IOS Release
WS-C3650-24TS
WS-C3650-48TS
WS-C3650-24PS
WS-C3650-48PS
WS-C3650-48FS
WS-C3650-24TD
WS-C3650-48TD
WS-C3650-24PD
WS-C3650-48PD
WS-C3650-48FD
WS-C3650-48FQ
WS-C3650-48PQ
WS-C3650-48TQ
WS-C3650-24PDM3
WS-C3650-48FQM3
WS-C3650-8X24UQ3
WS-C3650-12X48UQ3
WS-C3650-12X48UR3
WS-C3650-12X48UZ3
GLC-T (10/100/1000)
GLC-TE
GLC-LH-SM
GLC-LH-SMD
GLC-SX-MM
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-T
SFP-GE-Z
DWDM SFP
DWDM SFP (add.)
XE 3.3.0SE
XE 3.3.0SE
GLC-BX40-D-I
GLC-BX40-DA-I
GLC-BX40-U-I
GLC-BX80-D-I
GLC-BX80-U-I
XE 3.7.1E
XE 3.7.1E
Please rate the comment if it is useful, thanks
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you for the answer. bye
You are welcome,
Have a great day.
Cisco WS-C3650X-48PD-S,check this switch,i can add this converter  module GLC-SX-MMD
