SFP Module issue
naveen_yummy
Hi guys,
In my Cisco 3750 get rebooted and now the SFP module is not working.
It showing the following error message.
05:13:22: %PHY-4-CHECK_SUM_FAILED: SFP EEPROM data check sum failed for SFP inte
rface Gi1/0/26
05:13:22: %GBIC_SECURITY_CRYPT-4-ID_MISMATCH: Identification check failed for GB
IC in port Gi1/0/26
What is the error message indicating and what is the solution for this.
thanks in advance
Naveen
Hi Naveen,
SFP EEPROM data check sum failed for SFP interface [chars]
The SFP was identified as a Cisco SFP, but the system was unable to readvendor-data information to verify its correctness.
Recommended Action: Remove and reinsert the SFP. If it fails again in the same way, the SFP may be defective.
Dan
