SFP Questions
The_guroo_2
Level 2
Level 2
Guys we have two type of swicthes
First of all i need to know what does 1000BT means ...will it have a normal RJ4 connector can i use both a port-channel to the core??? secondly the SFP on this can i use a RJ 45 SFP??? as my core swicth has only RJ 45 connector the same goes for the below switch which has only 4X SFP
Thanks heaps i tried looking on cisco but couldnt find the answer
Thanks heaps
WS-C2960-48PST-SLAN Lite Entry Layer 248 PoE2x1000BT and 2xSFP
Cisco Catalyst
2960S-48TS-L
48
  4 SFP
Leo Laohoo
Means 1000BaseTx.
Depends on the appliance.  A lot of switches support GLC-TX of SFP-GE-T but some models of switches will only support the SFP to operate in a single speed.
Cisco Small Form-Factor Pluggable (SFP) Transceiver Modules Maintenance and Troubleshooting
