SFP showing unknown on Nexus 7000! Plz help
fariha zain
I have couple of SFP and most of them are working fine except this:-
Nexus7000# show interface ethernet 6/31 transceiver details
Ethernet6/31
    sfp is present
    type is 10Gbase-(unknown)  <<<< Why is this nt getting recognized.
    name is CISCO-AVAGO
    part number is SFBR-5766PZ-CS1
    revision is
    serial number is  AGXXXXXXXXX
    nominal bitrate is 1300 MBit/sec
    Link length supported for 50/125 um fiber is 550 m
    Link length supported for 62.5/125 um fiber is 270 m
    cisco id is --
    cisco extended id number is 4
   SFP calibration is invalid <<<<<<<<<<< SFP is invalid.
a) What is the reason this is not getting recognized?
b) Is theSFP SFBR-5766PZ-CS1 plug and play in the 7000 Nexus?
Thanks in advance.
Fari
Based from the following output:
Ethernet6/31
    sfp is present
    name is CISCO-AVAGO
    revision is
    cisco id is --
Nexus# show int E6/31 capabilities
Ethernet6/31
  Model:                 N7K-M132XP-12
Type (SFP capable):    10Gbase-(unknown)
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
You put a 1GE SFP into the M132 line card and M132 only support 10GE SFP. The conclusion is your are using the wrong SFP.
jerry
7 Replies 7
Leo Laohoo
What is the exact model of SFP+ and the NX-OS you are running?
HI Leo,
Nexus :7010
S/W: 4.2
Ethernet6/31
  Speed:                 10000
  Duplex:                full
NOTe: I have the other SFP but they are working fine expect only this.
Ehter 6/1-30             P/N SFBR-7700SDZ-CS2
Ether6/31                   P/N SFBR-5766PZ-CS1  <<< Is there any issue with this SFP?
Thanks in advance.
Fari
I think I have an idea what's going on ...
PID "SFBR-5766PZ-CS1" is a 1000BaseFX SFP and you are running NX-OS 4.X.
Is this SFP module installed in a M148 line card?  If not, then you need to upgrade the NX-OS to the appropriate level as stated in the Release Notes (Table 4).
Ethernet6/31
    sfp is present
    name is CISCO-AVAGO
    revision is
    cisco id is --
Ethernet6/31
  Speed:                 10000
  Duplex:                full
jerry
Nice catch, Jerry!
Hi Leo,
My customer called me every month for the same problem. =)
jerry
LOL!
