SFP TO FIBER COVERTER CONNECTION
ashley.1232
Hello ,
Iam trying to configure the following scenario,
i have a cisco WS-C3560X-48T-S , with 12.2(58r)SE1 ios , when iam trying to have the following connection
CISCO 3560 SW with SFP port access vlan CAM------Fiber Cable--------->Fiber Converter-------UTP CABLE---------CCTV CAM.
Iam going with this scenario unfortunately , the SFP PORT is not going up.
Please can somebody help me to see if this scenario applicable.
Thank you..
Fibre does not support auto-negotiation.
If you have a 100Mb/s fibre convert you need a 100Mb/s SFP.  It sounds like you need to get a 1000BaseSX fibre media converter.
6 Replies 6
Philip D'Ath
Receive and transmit fibres crossed over?
Does the fibre media convert have the same specs as the SFP?  Both 1000baseX for example.
Hello Philip,
Yeah already crossed over the TX RX of the fiber cables, and still the same , i have the SFP 1000Base X, dont know whats my FIber converter speed, but its written on the fober converter 10/100 Ethernet , there is no speed discription for the fiber interface in the fiber converter.
But its still the speed is auto on the switch port , does it make any conflict?
Thank you..
Hello Philips,
Yeah seems its a speed issue, but the weird thing is that , iam not able to change the speed configuration under the port having the SFP inserted in it.
when you put speed you will get the following :-
SW(config-if)#spe
SW(config-if)#speed ?
nonegotiate Do not negotiate speed
SW(config-if)#speed
Thank you..
Fibre doesn't support speed negotiation.  You have to buy the SFP/Media converter for the specific speed you want to run.
As the media converter is cheaper, I would replace that with a 1000BaseSX unit.
Thank you Philip For you Help :)
