02-19-2019 12:18 PM - edited 03-08-2019 05:23 PM
Hello buddies,
There are some Switches SG220-50 on my network and since when I installed them, I get packet loss when ping to the their management interface.
Esgotado o tempo limite do pedido.
Resposta de 10.17.4.1: bytes=32 tempo=1732ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1710ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1715ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1748ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1904ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1757ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=1734ms TTL=64
Resposta de 10.17.4.1: bytes=32 tempo=2ms TTL=64
If you ping to a device connected to the any port of the Switch at the same time there is no packet lost while you can see a packet lost on the management interface.
Do anybody had the same issue ? What could I do to solve it ?
Many Thanks in advance.
02-19-2019 12:21 PM
02-19-2019 02:24 PM
in addition to the other post, make sure you are running the latest firmware release on your switch, which currently is release 1.1.4.1
