SG350 remote access from vlan210 to vlan1
IAmSeth
I am trying to setup the switch SG350 to allow remote access to the web interface from another vlan that will below to IT group.
Vlan 1 = 192.168.0.254 255.255.255.0 no port connected
Vlan200 = 192.168.200.254 255.255.255.0 port 1 connected
Ip routing enabled
Do i need to setup access group to improve security?
I was working on older switches up until now and to enable remote access i had to generate RSA key, is it a case on the SG350 switch too?
All help will be much appreciated.
#1: Should you set up an access-group for connectivity.
I would say "always", just because I like security. You don't necessarily have to, but I would recommend it.
#2: Do you need to generate a RSA key.
Yes, unless you're using Telnet (ill-advised). I would generate a decent key length and enable SSH2.
Thank you for your response.
That is partial information that i need. I need to get remote connection to Vlan 1, best through other Vlan that will be connected to the network.
