SG350 VLAN question if configured correct for 1 host per vlan/port
S3C
This is 1 part of a big conf of only LAN.
Below I kinda want to get OK if done right, totally wrong or missed something in the conf.
5 Hosts = 5 VLANs/Ports (mode access)
1 host per VLAN/Port
Interface 1 = VLAN 1 = IP x.x.10.10/24
Interface 2 = VLAN 2 = IP x.x.20.10/24
etc
Port 9 is trunked to a FW
switchport mode trunk
switchport trunk allowed vlan 10,20,30,40,50
switchport nni ethtype dot1q
Hosts will have static IP so no need for DHCP per vlan right?
CLI output:interface GigabitEthernet1
switchport access vlan 10
spanning-tree bpduguard enable
interface GigabitEthernet2
switchport access vlan 20
interface vlan 10
ip address x.x.10.10 255.255.255.0
interface vlan 20
ip address x.x.20.10 255.255.255.0
Attached is a diagram of the idea
design looks by the book. If you do this in Packet Tracer, keep in mind that the 5505 doesn't do subinterfaces, you need the 5506X. Other than that, I guess you know how to configure the ASA ?
Hello!
Im using a Cisco FTD 1010 for FW.
I have configured sub-interfaces on the 1 trunk port with above VLAN IDs & IPs.
