I'm trying to figure out if "budgeted" power will limit the number of devices I can power up with my SG350X-48P switch.
When I "show power inline"
The consumed power is showing whats been cumulatively budgeted by each device connected on the switch.
For example, I have 2 x 802.3at WiFi APs - budgeting for 25.5W each, but only consuming 9.8W each.
I'm worried that as IP-Phones get added, the PoE on the switch will go "over budget" and stop powering up additional devices while the actual power usage will be less than 50% of what's available. Make sense?
Output below has been edited for brevity.
show power inline
Power-limit mode: Class based
Usage threshold: 95%
Trap: Disable
Legacy Mode: Enable
Inrush Test: Enable
Class Error Detection: Enable
Unit Module Nominal Consumed Temp SW PSE chipset
Power (W) Power (W) (C) Version HW Revision
1 SG350X-48P 375 52 (14%) 44 23.190.18.3 PD69208 - 0x4A02
Interface Admin Oper Power (W) Class Device Priority
gi1/0/1 Auto On 9.800 (25.500) 4 high
gi1/0/25 Auto On 9.600 (25.500) 4 high
gi1/0/26 Auto Searching 0.0 0 high
gi1/0/27 Auto Searching 0.0 0 low
gi1/0/28 Auto Searching 0.0 0 low
