SG500x Layer 3 routing?
CaseyJ374
Hi, so I apologize at first that I'm new to this type of networking that I'm having to setup and could use some help:
I have 2 Cisco SG500X-24 switches that have 3 vlans (1, 5, 10) and connected via fiber (on different floors) on fiber port 2.  I have an IP address setup for the 5 vlan for management, and is untagged to access port 24, but tagged on fiber port 2 (trunk port).  The 10 vlan does not have an IP addresses, and it's untagged for ports 1-23, and fiber port 1 and tagged on fiber port 2 (trunk port).  The 1 vlan is not on any port.
From my ISP, (which is connected to fiber port 1),  I received a "Layer 3 IP" which consists of 50.0.0.40/30 (not real subnet) and has layer 3 ip of 50.0.0.42 with a default gateway of 50.0.0.41. This is the ISP's gateway.  Also, I was given a /25 subnet, of 50.0.0.128/25 but no gateway.  Just a block of IP's.
Each 1-23 port on each switch (in the 10 vlan) needs to be able to use one of the /25's, however, I'm not sure what to add where to get this routing to work.
I know that if I assign my laptop the IP from the /30, I can surf while plugged into any of the 1-23 ports, so I know the connection to the ISP is valid.  Finally, each port in the 1-23 is checked with "protected mode" so users can't go sniffing around.
Any help would be greatly appreciated!
6 Replies 6
Deepak Kumar
As I a getting your point that you are connecting your ISP connection direct to switch. But it is not possible becuase your ISP has supplied /30 subnet (Public IP). Now you need a router to perform NATing for your internal subnet. Your connection must be like:
ISP Connection-------->Router--------------->SG300
Public Network             NAT+routing                   Switching.
NATing is not possible on the SG300 Switch.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I’m not worried about the internal subnet, that will have a nat router connected later.. that is just a management ip (which is why its only on port 24 and tagged on the trunk to the other switch). It’s more about how to get the 50.0.0.128/25 to route.
50.0.0.40/30 and 50.0.0.128/25 are not overlapping, so why don't you just assign an IP address such as 50.0.0.129/25 to the VLAN 10 interface and then the remaining IP addresses from the 50.0.0.128/25 range to your clients in VLAN 10, with the VLAN 10 interface being the default gateway ?
Sorry if this sounds too simple, I might have missed your point...
I tried that, and couldn’t get any traffic to route. Do I need a separate vlan for the /30 directly connected to the isp’s fiber port, then the vlan 10 have the /25’s? If so, what would I add as my route to get the /25’s to route through the /30?
I assume you have IPv4 routing enabled (page 274 of the attached admin guide) ? Do you have the next hop router IP address defined as well (page 276) ? With IPv4 routing enabled, routing between your VLAN 10 interface and the WAN interface should be automatic...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/administration_guide/500_Series_Admin_Guide.pdf
This worked, and all is good. Thank you for your help!
