SGE2010P vlan issue
jakzolo82
Hi everyone,
i have created two vlans,
vlan 1 data and vlan 200 voice. the issue is that when an on one vlan i cannot ping the default gateway of the othe vlan from my PC.
an using sge 2010p switches.
below is my configuration
p route 0.0.0.0 0.0.0.0 192.168.0.1
ip dhcp relay address 192.168.0.100
ip dhcp relay enable
ip dhcp information option
interface vlan 1
exit
interface vlan 200
exit
interface range ethernet g(2-46,48)
exit
any one pliz assist.
Sandeep Choudhary
is it a layer 3 switch orlayer 2????
please check the ports, that should be in right vlan.
can u pasterur config.
it a layer 3. from the switch i can pingg both 192.168.0.11 and 10.0.1.1.
please chech and advise coz 1 want the ports to be on both vlans
below is my config.
CORE# sh run
no spanning-tree
spanning-tree mode rstp
switchport mode trunk
exit
vlan database
vlan 200
exit
switchport trunk allowed vlan add 200
exit
ip dhcp snooping vlan 1
ip dhcp snooping vlan 200
interface ethernet g2
ip dhcp snooping trust
exit
interface vlan 1
ip address 192.168.0.11 255.255.255.0
exit
interface vlan 200
ip address 10.0.1.1 255.255.255.0
exit
interface vlan 1
exit
interface vlan 200
exit
exit
i couldnt find the error in the config .
can you please remove this dhcp config setting and manually assign the ip to PCs and then try .
just see if yor are right or :
1. Put switch in layer3 mode via telnet or console, then reset the switch so that it takes affect.
2. Created 2 VLANs (e.g. 1 and 200 in the Bridging section of the webconfig.
3.  Assigned an IP address to each VLAN e.g. VLAN 1 = xxx.xxx.xxx.1/24  and VLAN 200 yyy.yyy.yyy.1  /24 in the ipv4 configuration section of  webconfig
4. Joined several ports to each VLAN.
5. Set up  all NICs on VLAN 1 that I want to communication with VLAN 200 with xxx.xxx.xxx.* /24 addresses and a default gateway of xxx.xxx.xxx.1 VLAN  1 IP address)
6. Set up all NICs on VLAN 200 that I want to  communication with VLAN 1 with yyy.yyy.yyy.* /24 addresses and a  default gateway of yyy.yyy.yyy.1 (VLAN 200 IP address)
or
Are you getting ip address in diff vlan by DHCP ???
