show cdp nei issue
Lim Seow Hua
Why i cannot see the neighbour in the "show cdp nei" command?
km61d-d5brs01#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi1/1(P)    Gi1/2(P)    Gi2/1(P)
                                 Gi2/2(P)
km61d-d5brs01#show cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
km61d-d5brs01#
Dasuntha Dinesh
Double check, maybe CDP is disable in the other side.
Dasuntha
We can notice this neighbour in the other side. But this switch cannot see its neigbhour
Richard Burts
There is not enough information here for us to know with certainty what is the issue.
My first guess is that either this device or the other device does not have CDP active on the interface.
It would help if you would post the output of show cdp interface from this device and from the other device. This would help to determine whether CDP is active on the correct interfaces.
Rick
Rick
