show cdp neighbor Output Is Not Correct on C2960S
Translator
Community Manager
Community Manager
Thank you all for your support.
I've encountered a strange incident, and I'm very happy to hear your advice.
Two 2960 (WS-C2960S-24TS-L IOS 15.0(2)SE) are connected to each other by GigabitEthernet1/0/21.
The following message was printed during system running
Nov 6 07:51:46.961 JST: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet1/0/21 (1), with SW-A GigabitEthernet1/0/24 (3).
I have successfully recovered by rebooting SW-A, but I think that there was something wrong on the SW-A side.
What kind of obstacles do you have? Or is there a bug that matches such an event?
◆When I pressed show cdp neighbor detail on the B side, it seems that Port24 on the A side is connected.
SWB#show cdp neighbors detail
Device ID: SW-A
Entry address(es):
IP address: XX.XXX.79.24
Platform: cisco WS-C2960S-24TS-L, Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/21, Port ID (outgoing port): GigabitEthernet1/0/24
Holdtime : 123 sec
Version :
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 28-Jul-12 00:42 by prod_rel_team
advertisement version: 2
Protocol Hello: OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF00000000000008CC68862280FF0000
VTP Management Domain: ''
Native VLAN: 3 (Mismatch)
Duplex: full
Power Available TLV:
Power request id: 0, Power management id: 1, Power available: 0, Power management level: -1
Management address(es):
SW-B#show mac address-table
3 08cc.6886.2297 DYNAMIC Gi1/0/21 <<< SW-A Gi1/0/23 Mac Address
3 08cc.6886.22c1 DYNAMIC Gi1/0/21 <<< SW-A Vlan3 Mac Add
SW-B#show int status GigabitEthernet1/0/21
GigabitEthernet1/0/21 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 08cc.6886.0515 (bia 08cc.6886.0515)
Description: to SW-A
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 3 packets/sec
43801432 packets input, 3679854700 bytes, 0 no buffer
Received 41353548 broadcasts (39258069 multicasts)
44 input errors, 44 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 39258069 multicast, 0 pause input
43659866 packets output, 3723907621 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
◆On the SW-A side, SW-B information is correctly recognized.
SW-A#show cdp neighbors detail
Device ID: SW-B
Entry address(es):
IP address: XX.XXX.80.24
Interface: GigabitEthernet1/0/21, Port ID (outgoing port): GigabitEthernet1/0/21
Holdtime : 175 sec
Version :
Protocol Hello: OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF00000000000008CC68860500FF0000
Native VLAN: 1
Duplex: full
4 08cc.6886.0515 DYNAMIC Gi1/0/21 <<< SW-B Gi1/0/21 Mac Address
SW-A#show int status GigabitEthernet1/0/21
Hardware is Gigabit Ethernet, address is 08cc.6886.2295 (bia 08cc.6886.2295)
Description: to SW-B
.Nov 6 12:53:20.779 JST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13, changed state to downrs never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 83
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 2000 bits/sec, 3 packets/sec
43696783 packets input, 3726750459 bytes, 0 no buffer
Received 41183914 broadcasts (39253813 multicasts)
0 watchdog, 39253813 multicast, 0 pause input
43819616 packets output, 3681232987 bytes, 0 underruns
7 Replies 7
Translator
Community Manager
Community Manager
@Translator
 Native vlan mismatch will not be fixed with reboot. We can see on the switch A
While in Switch b we can see
Native VLAN: 1
You need to fix it by change the native vlan on switch A to 1 or on switch B to 3.
Can I see the command output for:
"show run int GigabitEthernet1/0/21" and "show run int GigabitEthernet1/0/24" both switches.
Leo Laohoo
From Switch A, post the complete output to the command "sh run interface Gi1/0/21".
From Switch B, post the complete output to the command "sh run interface Gi1/0/24".
@Translator
Native VLAN: 1
Translator
Community Manager
Community Manager
While it would be good to correct this issue, as has been suggested. I will point out that this mismatch message is a cosmetic issue. Everything will run fine with the config as they are.
Rick
Translator
Community Manager
Community Manager
Thank you for your reply.
Even though SW-A Gi1/0/21 and SW-B Gi1/0/21 are connected, when you key the cdp neighbor command in SW-B, it displays information like SW-A's Gi1/0/24 is connected. (And MacAddress is SW-A's Gi1/0/23)
As a result, I think that VLAN Mismatch is occurring, so I don't think the setting is about this.
I think there was something wrong with SW-A, but I want to know what scenarios this could happen.
