Bookmark
Subscribe
2012
Show controllers ethernet output
jedavis
Level 4
Level 4
I recently configured a network with a 4500 Sup7E and a 3560G with jumbo frame support.  I am trying to confirm operation.  On the 4500 this is straight forward using "sho int g0/nn count detail".  A portion of that output lists tx and rx frame sizes:
Port              InPkts 64        OutPkts 64    InPkts 65-127    OutPkts 65-127
Gi7/22              1631978          10708759          2220567           2087120
Port         InPkts 128-255   OutPkts 128-255   InPkts 256-511   OutPkts 256-511
Gi7/22                 4629             48616           118361             29112
Port        InPkts 512-1023  OutPkts 512-1023
Gi7/22               136697             50803
Port       InPkts 1024-1518 OutPkts 1024-1518 InPkts 1519-1548 OutPkts 1519-1548
Gi7/22              3075507           2083072                7                 3
Port       InPkts 1549-9216 OutPkts 1549-9216
Gi7/22             10165747               225
The 3560 doesn't support that command.  The closest I can come to finding the number of jumbo packets is "show controllers ethernet" (example below).  On the transmit side I assume that jumbo frames would be tallied in the "Too large frames" counter.  The receive side is a little more ambiguous.  There are 2 counters that seem to be duplicates, "Valid frames, too large" and "Valid oversize frames".  In operation they are not.  I am seeing the "Valid frames, too large" counter incrementing while the "Valid oversize frames" remains at zero.  The command reference doesn't help disambiguate this too much:
Invalid frames, too large:    The number of frames received that were larger than maximum allowed MTU size (including the FCS bits and excluding the frame header) and that have either an FCS error or an alignment error.
Valid frames, too large:  The number of frames received on an interface that are larger than the maximum allowed frame size.
Valid oversize frames:    The number of frames received on an interface that are larger than the maximum allowed frame size and have valid FCS values. The frame size includes the FCS value but does not include the VLAN tag.
What is "the maximum allowed frame size"?  The standard 1500 bytes or the 9000 bytes I configured?  Does anyone know how to monitor switching of jumbo frames?  Is there another command?
Switch#show contr ether g0/17
     Transmit GigabitEthernet0/17             Receive
    684222060 Bytes                       2135012435 Bytes
      8847049 Unicast frames                 7946185 Unicast frames
       134833 Multicast frames                    80 Multicast frames
         3890 Broadcast frames                    10 Broadcast frames
            0 Too old frames              2134998162 Unicast bytes
            0 Deferred frames                  13633 Multicast bytes
            0 MTU exceeded frames                640 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames             3468166 Minimum size frames
            0 8 collision frames             1140891 65 to 127 byte frames
            0 9 collision frames                 514 128 to 255 byte frames
            0 10 collision frames             117680 256 to 511 byte frames
            0 11 collision frames              88850 512 to 1023 byte frames
            0 12 collision frames            2204544 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames            925630 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      2015060 64 byte frames                       0 Valid frames, too small
       755379 127 byte frames
        19709 255 byte frames                      0 Too old frames
        40955 511 byte frames                     0 Valid oversize frames
       257472 1023 byte frames                     0 System FCS error frames
      5897197 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
-Jeff
0 Replies 0
