Show interface counters detailed
venkateshwarlu.t
Community Member
I can not output errors in the output of command "Show int e139/1/27" but I can see output errors in the output of command "Show int e139/1/27  counters detailed"
Why it is ? What it mean ? someone please could help.
SCH127# sh int Ethernet139/1/27
Ethernet139/1/27 is up
Hardware: 100/1000 Ethernet, address: bc67.1c39.471c (bia bc67.1c39.471c)
Description: AAA
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
full-duplex, 1000 Mb/s
Beacon is turned off
Input flow-control is off, output flow-control is on
Switchport monitor is off
EtherType is 0x8100
Last link flapped 00:59:45
Last clearing of "show interface" counters 00:48:18
0 interface resets
30 seconds input rate 84640 bits/sec, 52 packets/sec
30 seconds output rate 176760 bits/sec, 45 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 82.43 Kbps, 63 pps; output rate 392.92 Kbps, 70 pps
RX
169718 unicast packets 0 multicast packets 202 broadcast packets
169920 input packets 31397344 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
172281 unicast packets 959 multicast packets 5375 broadcast packets
179302 output packets 114400660 bytes
1 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
SCH127# sh int Ethernet139/1/27 counters detailed
Ethernet139/1/27
Rx Packets: 173563
Rx Unicast Packets: 173357
Rx Broadcast Packets: 206
Rx Bytes: 32082305
Tx Packets: 182764
Tx Unicast Packets: 175644
Tx Multicast Packets: 978
Tx Broadcast Packets: 5420
Tx Bytes: 116422663
Output Errors: 722
venkateshwarlu.t
Community Member
These output errors increasing ... any one any idea ?
Nexus Fex Switch port
