Show Interface Status not showing ALL interfaces
Community,
I have a 7710 Nexus switch with 8 line cards in it. The line card in slot 8 is a  N77-F348XP-23. It has 48 ports. However, when I run a " show interface status" it only brings up Eth8/1 - Eth8/40. Ports 41 - 48 do not show up at all. Is this a bug or some other limitation in the NXOS?
Software
BIOS: version 3.1.0
kickstart: version 6.2(12)
system: version 6.2(12)
BIOS compile time: 02/27/2013
kickstart image file is: bootflash:///n7700-s2-kickstart.6.2.12.bin
kickstart compile time: 12/3/2014 18:00:00 [02/02/2015 21:11:17]
system image file is: bootflash:///n7700-s2-dk9.6.2.12.bin
system compile time: 12/3/2014 18:00:00 [02/02/2015 22:42:21]
Hardware
cisco Nexus7700 C7710 (10 Slot) Chassis ("Supervisor Module-2")
Intel(R) Xeon(R) CPU with 32745060 kB of memory.
Processor Board ID JAE193007X6
Any insights you can provide are helpful. Thank you.
I believe I found the answer. Under the VDC context config, the following was found:
Does anyone know if issuing the "allocate interface Ethernet8/1-48 is disruptive? Will the line card have to cycle?
Thank you.
