show running can't display some commands on Cisco 2921
Pengfei Wang
Hello everyone
I have a CISCO2921/K9 router running 15.1(4)M4, I entered follow commands :
ip subnet-zero
no service finger
no boot network
But i can't see any output about these commands use show running/show running all
Any method can display these commands?
Thank you
Reza Sharifi
Usually if a command is disabled or enabled by default, the IOS does not show it in the running config. For example, in the newer IOS versions ip subnet-zero is enabled by default, so the IOS does not show it in the config. no service finger has been replaced by no ip finger and it is disabled by default.  See this document for more info:
http://www.cisco.com/c/en/us/td/docs/ios/fundamentals/command/reference/cf_book/cf_r1.html#wp1014016
Thank you very much.
Hi Reza
"Usually if a command is disabled or enabled by default, the IOS does not show it in the running config. For example, in the newer IOS versions ip subnet-zero is enabled by default, so the IOS does not show it in the config."
Is there a ducument explain this?
