Simple 802.1X with 2950 and IAS and a work group
bob.bartlett
I am having troubles with getting my client to authenticate properly with my Windows 2000 Server running IAS. Their is no domain just a work group. It looks as though the server authenticates it but all i ever get is UNAUTHORIZED
5 Replies 5
Marwan ALshawi
did checked that the communication between the switch and IAS working
witch test aaa authen usename
make sure the authentication working first
I am getting messages in the IAS logs and am getting messages that the switch is sending the request.
r u useing certificate for PC authentication ?
No I am not using certificates. Username and Password only.
hi
use the attached File as refrence to check your config
good luck
if helpful rate
