Simple NAT Translation
jfraasch
Level 3
Level 3
I am trying to NAT a webserver to a routable IP address.  I just have the server directly plugged into my router and need to NAT its IP (172.30.194.131) to the other side of the router (172.30.180.28).
Here is the config:
interface FastEthernet0/0
ip address 172.30.180.25 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.30.194.135 255.255.255.192
ip nat outside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 172.30.180.1
no ip http server
ip nat inside source static 172.30.194.131 172.30.180.28
ip nat outside source static 172.30.194.131 172.30.180.28
That's it.
Now, my pings work fine and when I show IP NAT Translations I can see the translation table.  But I cannot HTTP to the same IP address.  I don't think there is anything special to do with HTTP.  Any thoughts?
James
mrdogantr
access-list 20 permit WEB_SERVER_LOCAL_IP
ip nat pool websrv WEB_SERVER_PUBLIC_IP  WEB_SERVER_LOCAL_IP netmask 255.255.255.252
ip nat inside source list 20 pool websrv overload
ip nat inside source static tcp WEB_SERVER_LOCAL_IP 80 WEB_SERVER_PUBLIC_IP 80
hth
Muammer
5 Replies 5
mrdogantr
hth
Muammer
So you are saying I need a specific NAT for HTTP?
I will give it a shot.
James
Hi James,
don't need a specific NAT, you can try,
or
ip nat inside source static WEB_SERVER_LOCAL_IP  WEB_SERVER_PUBLIC_IP
hth
Muammer
Hi James,
you can define simple nat like below to be able to connect that nated server through http (80)
ip nat inside source static tcp 10.50.50.52 80 196.27.24.79 80 extendable
Please rate if this helped you...
Naidu.
It was much easier than this.
I had it right. The server team had the wrong default gateway.  My NAT Translations were looking all good and everything so I couldn't figure it out until I started at the bottom and worked my way up.
Since this is a test box only on the inside corporate network I didnt need the port 80 only open.
Thanks for the help!
James
