09-22-2017 11:07 AM - edited 03-08-2019 12:08 PM
Hi everybody,
I tried to setup a simple L2/L3 routing environment with switch and router, just for learning purpose. Please see attached screenshot for the topology. It does not work, I cannot figure out why. Both PC can ping each other and can ping L3-port on switch(192.168.0.1). From switch I can ping everything and from router as well. But what I cannot ping is from PC to routers IP addresses. I would expect to be able to ping both of them. What's wrong?
Thanks for anyone to have a look at that,
Stefano
Excerpts from the configs:
Config on Switch 3650:
ip routing
interface GigabitEthernet1/0/1
switchport access vlan 10
interface GigabitEthernet1/0/2
switchport access vlan 20
interface GigabitEthernet1/0/24
no switchport
ip address 192.168.0.1 255.255.255.248
interface Vlan10
ip address 10.1.1.1 255.0.0.0
interface Vlan20
ip address 10.2.2.1 255.0.0.0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1/0/24
Config on Router 2911:
interface GigabitEthernet0/0
ip address 192.168.0.2 255.255.255.248
interface GigabitEthernet0/1
ip address 99.0.0.1 255.0.0.0
interface GigabitEthernet0/2
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 99.0.0.2
Solved! Go to Solution.
09-23-2017 12:35 AM
09-23-2017 12:35 AM
09-23-2017 01:25 AM - edited 09-23-2017 01:27 AM
Route on 2911 is missing (as meheretabm said, but just one route is missing)
ip route 10.0.0.0 255.0.0.0 192.168.0.1
However:
interface Vlan10
interface Vlan20
Should not be allowed on device (at least with both interfaces active) since network IP address ranges overlap.
09-23-2017 02:14 AM - edited 09-23-2017 02:16 AM
Hi Meheretab, hi Predrag,
thanks to both of you. Backwards routes where missing, now it works. And yes, the subnet mask for SVI addresses was wrong in my posting, on the switch it was correct (255.255.255.0).
Sorry for creating efforts, should have seen that myself.
Regards, Stefano
