Site to 2 Sites VPN Problem - Resolved
vcapeci46
I want to set up 2 tunnels
From Site A to Site B
From Site A to Site C
Config Router site A
pseudowire-class PW_2
 encapsulation l2tpv3
 protocol l2tpv3 tunel
 ip local interface GigabitEthernet0
crypto keyring key_tunel_UNION_T2370
  pre-shared-key address {Ip address site B} key {key1}
crypto isakmp policy 1
 authentication pre-share
 group 2
 lifetime 3600
 encryption 3des
crypto isakmp profile profile_tunel_UNION_T2370
   match identity address {ip address site B}{mask site B}
crypto ipsec transform-set strong ah-sha-hmac esp-3des
 mode tunnel
 crypto map ipsec-maps 10 ipsec-isakmp
 set peer {ip address site B}
 set transform-set strong
 set isakmp-profile profile_tunel_UNION_T2370
 match address acl_tunel_UNION_T2370
crypto map ipsec-maps 20 ipsec-isakmp
 description ** tunel_ALU_T2371 **
 set peer {ip address site C}
 set isakmp-profile profile_tunel_ALU_T2371
 match address acl_tunel_ALU_T2371
interface FastEthernet5
 switchport access vlan 4
 no ip address
interface FastEthernet6
 switchport access vlan 3
 no ip address
 ip address {ip address site A}  {mask site B}
 ip access-group 1 in
 duplex auto
 speed auto
 dot1q tunneling ethertype 0x9100
 vlan-id dot1q 3
  exit-vlan-config
 vlan-id dot1q 4
  exit-vlan-config
interface Vlan3
 no ip address
 xconnect  {ip address  site B}  3 encapsulation l2tpv3 pw-class PW_2
interface Vlan4
 no ip address
 xconnect {ip address  site C} 4 encapsulation l2tpv3 pw-class PW_2
ip access-list extended acl_tunel_ALU_T2371
 permit ip any any
ip access-list extended acl_tunel_UNION_T2370
 permit ip any any
 On router B I have the same configuration except the crypto map of site C because I do not need connection between Site B and site C
 When I execute debug isakmp I get the following messages
*Sep 21 15:20:27.548: ISAKMP (0): received packet from {IP Site B} dport 500 sport 500 Global (N) NEW SA
*Sep 21 15:20:27.548: ISAKMP: Created a peer struct for {IP Site B}, peer port 500
*Sep 21 15:20:27.548: ISAKMP: New peer created peer = 0x8C0EDDB4 peer_handle = 0x800000A4
*Sep 21 15:20:27.548: ISAKMP: Locking peer struct 0x8C0EDDB4, refcount 1 for crypto_isakmp_process_block
*Sep 21 15:20:27.548: ISAKMP: local port 500, remote port 500
*Sep 21 15:20:27.548: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 8C1EF404
*Sep 21 15:20:27.548: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Sep 21 15:20:27.548: ISAKMP:(0):Old State = IKE_READY  New State = IKE_R_MM1
*Sep 21 15:20:27.548: ISAKMP:(0): processing SA payload. message ID = 0
*Sep 21 15:20:27.548: ISAKMP:(0): processing vendor id payload
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
*Sep 21 15:20:27.548: ISAKMP (0): vendor ID is NAT-T RFC 3947
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
*Sep 21 15:20:27.548: ISAKMP (0): vendor ID is NAT-T v7
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID is NAT-T v3
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
*Sep 21 15:20:27.548: ISAKMP:(0): vendor ID is NAT-T v2
*Sep 21 15:20:27.548: ISAKMP:(0):found peer pre-shared key matching {IP Site B}
*Sep 21 15:20:27.548: ISAKMP:(0): local preshared key found
*Sep 21 15:20:27.548: ISAKMP : Scanning profiles for xauth ... profile_tunel_ALU_T2371 profile_tunel_UNION_T2370
*Sep 21 15:20:27.548: ISAKMP:(0):Checking ISAKMP transform 1 against priority 1 policy
*Sep 21 15:20:27.548: ISAKMP:      encryption 3DES-CBC
*Sep 21 15:20:27.548: ISAKMP:      hash SHA
*Sep 21 15:20:27.548: ISAKMP:      default group 2
*Sep 21 15:20:27.548: ISAKMP:      auth pre-share
*Sep 21 15:20:27.548: ISAKMP:      life type in seconds
*Sep 21 15:20:27.548: ISAKMP:      life duration (basic) of 3600
*Sep 21 15:20:27.552: ISAKMP:(0):atts are acceptable. Next payload is 0
*Sep 21 15:20:27.552: ISAKMP:(0):Acceptable atts:actual life: 0
*Sep 21 15:20:27.552: ISAKMP:(0):Acceptable atts:life: 0
*Sep 21 15:20:27.552: ISAKMP:(0):Basic life_in_seconds:3600
*Sep 21 15:20:27.552: ISAKMP:(0):Returning Actual lifetime: 3600
*Sep 21 15:20:27.552: ISAKMP:(0)::Started lifetime timer: 3600.
*Sep 21 15:20:27.552: ISAKMP:(0): processing vendor id payload
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
*Sep 21 15:20:27.552: ISAKMP (0): vendor ID is NAT-T RFC 3947
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
*Sep 21 15:20:27.552: ISAKMP (0): vendor ID is NAT-T v7
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID is NAT-T v3
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
*Sep 21 15:20:27.552: ISAKMP:(0): vendor ID is NAT-T v2
*Sep 21 15:20:27.552: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Sep 21 15:20:27.552: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM1
*Sep 21 15:20:27.552: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
*Sep 21 15:20:27.552: ISAKMP:(0): sending packet to {IP Site B} my_port 500 peer_port 500 (R) MM_SA_SETUP
*Sep 21 15:20:27.552: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Sep 21 15:20:27.552: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Sep 21 15:20:27.552: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM2
*Sep 21 15:20:27.560: ISAKMP (0): received packet from {IP Site B} dport 500 sport 500 Global (R) MM_SA_SETUP
*Sep 21 15:20:27.560: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Sep 21 15:20:27.560: ISAKMP:(0):Old State = IKE_R_MM2  New State = IKE_R_MM3
*Sep 21 15:20:27.560: ISAKMP:(0): processing KE payload. message ID = 0
*Sep 21 15:20:27.576: ISAKMP:(0): processing NONCE payload. message ID = 0
*Sep 21 15:20:27.576: ISAKMP:(0):found peer pre-shared key matching {IP Site B}
*Sep 21 15:20:27.576: ISAKMP:(2083): processing vendor id payload
*Sep 21 15:20:27.576: ISAKMP:(2083): vendor ID is DPD
*Sep 21 15:20:27.576: ISAKMP:(2083): speaking to another IOS box!
*Sep 21 15:20:27.576: ISAKMP:(2083): vendor ID seems Unity/DPD but major 213 mismatch
*Sep 21 15:20:27.576: ISAKMP:(2083): vendor ID is XAUTH
*Sep 21 15:20:27.576: ISAKMP:received payload type 20
*Sep 21 15:20:27.576: ISAKMP (2083): His hash no match - this node outside NAT
*Sep 21 15:20:27.576: ISAKMP (2083): No NAT Found for self or peer
*Sep 21 15:20:27.576: ISAKMP:(2083):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Sep 21 15:20:27.576: ISAKMP:(2083):Old State = IKE_R_MM3  New State = IKE_R_MM3
*Sep 21 15:20:27.580: ISAKMP:(2083): sending packet to {IP Site B} my_port 500 peer_port 500 (R) MM_KEY_EXCH
*Sep 21 15:20:27.580: ISAKMP:(2083):Sending an IKE IPv4 Packet.
*Sep 21 15:20:27.580: ISAKMP:(2083):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Sep 21 15:20:27.580: ISAKMP:(2083):Old State = IKE_R_MM3  New State = IKE_R_MM4
*Sep 21 15:20:27.604: ISAKMP (2083): received packet from {IP Site B} dport 500 sport 500 Global (R) MM_KEY_EXCH
*Sep 21 15:20:27.604: ISAKMP: reserved not zero on ID payload!
*Sep 21 15:20:27.604: %CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from {IP Site B} failed its sanity check or is malformed
*Sep 21 15:20:27.604: ISAKMP (2083): incrementing error counter on sa, attempt 1 of 5: reset_retransmission
*Sep 21 15:20:28.604: ISAKMP:(2083): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:28.604: ISAKMP (2083): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Sep 21 15:20:28.604: ISAKMP:(2083): sending packet to {IP Site B} my_port 500 peer_port 500 (R) MM_KEY_EXCH
*Sep 21 15:20:28.604: ISAKMP:(2083):Sending an IKE IPv4 Packet.
*Sep 21 15:20:29.108: ISAKMP (2083): received packet from {IP Site B} dport 500 sport 500 Global (R) MM_KEY_EXCH
*Sep 21 15:20:29.108: ISAKMP:(2083): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:29.108: ISAKMP:(2083): retransmission skipped for phase 1 (time since last transmission 504)
*Sep 21 15:20:31.436: ISAKMP:(2082): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:31.436: ISAKMP (2082): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Sep 21 15:20:31.436: ISAKMP:(2082): sending packet to {IP Site B} my_port 500 peer_port 500 (I) MM_KEY_EXCH
*Sep 21 15:20:31.436: ISAKMP:(2082):Sending an IKE IPv4 Packet.
*Sep 21 15:20:31.440: ISAKMP (2082): received packet from {IP Site B} dport 500 sport 500 Global (I) MM_KEY_EXCH
*Sep 21 15:20:31.440: ISAKMP:(2082): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:31.440: ISAKMP:(2082): retransmission skipped for phase 1 (time since last transmission 4)
*Sep 21 15:20:39.108: ISAKMP:(2083): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:39.108: ISAKMP (2083): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Sep 21 15:20:39.108: ISAKMP:(2083): sending packet to {IP Site B} my_port 500 peer_port 500 (R) MM_KEY_EXCH
*Sep 21 15:20:39.108: ISAKMP:(2083):Sending an IKE IPv4 Packet.
*Sep 21 15:20:39.108: ISAKMP (2083): received packet from {IP Site B} dport 500 sport 500 Global (R) MM_KEY_EXCH
*Sep 21 15:20:39.108: ISAKMP:(2083): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:39.108: ISAKMP:(2083): retransmission skipped for phase 1 (time since last transmission 0)
*Sep 21 15:20:41.436: ISAKMP:(2082): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:41.436: ISAKMP (2082): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Sep 21 15:20:41.436: ISAKMP:(2082): sending packet to {IP Site B} my_port 500 peer_port 500 (I) MM_KEY_EXCH
*Sep 21 15:20:41.436: ISAKMP:(2082):Sending an IKE IPv4 Packet.
*Sep 21 15:20:41.440: ISAKMP (2082): received packet from {IP Site B} dport 500 sport 500 Global (I) MM_KEY_EXCH
*Sep 21 15:20:41.440: ISAKMP:(2082): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:41.440: ISAKMP:(2082): retransmission skipped for phase 1 (time since last transmission 4)
*Sep 21 15:20:49.108: ISAKMP:(2083): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:49.108: ISAKMP (2083): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Sep 21 15:20:49.108: ISAKMP:(2083): sending packet to {IP Site B} my_port 500 peer_port 500 (R) MM_KEY_EXCH
*Sep 21 15:20:49.108: ISAKMP:(2083):Sending an IKE IPv4 Packet.
*Sep 21 15:20:49.108: ISAKMP (2083): received packet from {IP Site B} dport 500 sport 500 Global (R) MM_KEY_EXCH
*Sep 21 15:20:49.108: ISAKMP:(2083): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:49.108: ISAKMP:(2083): retransmission skipped for phase 1 (time since last transmission 0)
*Sep 21 15:20:49.876: ISAKMP: set new node 0 to QM_IDLE
*Sep 21 15:20:49.876: ISAKMP:(2082):SA is still budding. Attached new ipsec request to it. (local 190.64.91.235, remote {IP Site B})
*Sep 21 15:20:49.876: ISAKMP: Error while processing SA request: Failed to initialize SA
*Sep 21 15:20:49.876: ISAKMP: Error while processing KMI message 0, error 2.
*Sep 21 15:20:51.436: ISAKMP:(2082): retransmitting phase 1 MM_KEY_EXCH...
*Sep 21 15:20:51.436: ISAKMP (2082): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Sep 21 15:20:51.436: ISAKMP:(2082): sending packet to {IP Site B} my_port 500 peer_port 500 (I) MM_KEY_EXCH
*Sep 21 15:20:51.436: ISAKMP:(2082):Sending an IKE IPv4 Packet.
*Sep 21 15:20:51.440: ISAKMP (2082): received packet from {IP Site B} dport 500 sport 500 Global (I) MM_KEY_EXCH
*Sep 21 15:20:51.440: ISAKMP:(2082): phase 1 packet is a duplicate of a previous packet.
*Sep 21 15:20:51.440: ISAKMP:(2082): retransmission skipped for phase 1 (time since last transmission 4)
Router_GC2#no debug crypto isakmp
Crypto ISAKMP debugging is off
Do you guys have an idea of what I´m doing wrong? Thanks in advance for your repplies
Although I am not familiar with this sort of vpn configuration, the one thing I notice in your config is
 permit ip any any
 permit ip any any
So how do you know which tunnel to send the traffic to for the remote sites?
Thanks you for your reply. That is made on the vlan interface with the xconnect command. I think that the problem is an authentication issue but I still could not resolved it. I will try to be more specific on the access list and I post the results. Regards,
Valentin
vcapeci46
I manage to set up the 2 tunnels the problem was on the definition of the pre shared key. I was missing the mask. So the correct script is:
  pre-shared-key address {Ip address site B} {Mask} key {key1} on both sites
