Site to site vpn woes
holloway5
Hi, we've got a cisco 2801 in our head office and an asa5505 in our remote office.
H/o network is 192.168.24.0/24 and remote is 192.168.101.0/24. We have a server in head office which as a public IP natted to it (shown as !!!.!!!.40.69 in the config below). Problem is, this server can not get to the 101 network. Traceroute on the server tries to go out through the internet, rather than via the site to site link.
Can anyone advise, here's the cutdown config for the 2801
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp key q**! address ***.ABC.DEF.39
crypto ipsec transform-set ASA-IPSEC esp-3des esp-sha-hmac
crypto map mymap 10 ipsec-isakmp
set peer ***.ABC.DEF.39
set transform-set ASA-IPSEC
match address 101
interface FastEthernet0/0
description *** LAN ***
ip address 192.168.24.1 255.255.255.0
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
load-interval 60
duplex auto
speed auto
no cdp log mismatch duplex
ip nat inside source list 150 interface FastEthernet0/1 overload
ip nat inside source static 192.168.24.6 !!!.!!!.40.67
ip nat inside source static 192.168.24.14 !!!.!!!.40.69
ip nat inside source static tcp 192.168.24.20 8980 !!!.!!!.40.70 8980 extendable
ip nat inside source static 192.168.24.243 !!!.!!!.40.75
ip nat inside source static 192.168.24.92 !!!.!!!.40.77
ip nat inside source static tcp 192.168.24.3 80 !!!.!!!.40.78 80 extendable
ip nat inside source static tcp 192.168.24.3 443 !!!.!!!.40.78 443 extendable
ip nat outside source static tcp 192.168.24.26 80 !!!.!!!.40.73 80 extendable
ip nat outside source static tcp 192.168.24.26 443 !!!.!!!.40.73 443 extendable
ip access-list extended PROTECT
permit icmp any any
permit udp any host !!!.!!!.40.66 eq isakmp
permit udp any host !!!.!!!.40.66 eq non500-isakmp
permit esp any host !!!.!!!.40.66
permit udp any eq domain any
permit tcp any any established
permit tcp any eq ftp-data any syn
permit tcp any host !!!.!!!.40.68 eq 443
permit tcp any host !!!.!!!.40.69 eq ftp
permit udp any host !!!.!!!.40.69 eq isakmp
permit tcp any host !!!.!!!.40.69 eq 443
permit tcp any host !!!.!!!.40.69 eq 1723
permit tcp any host !!!.!!!.40.69 eq 22
permit tcp any host !!!.!!!.40.69 eq www
permit udp any host !!!.!!!.40.69 eq non500-isakmp
permit udp any host !!!.!!!.40.69 eq 1701
permit gre any host !!!.!!!.40.69
permit tcp any host !!!.!!!.40.73 eq www
permit tcp any host !!!.!!!.40.73 eq 443
permit tcp any host !!!.!!!.40.74 eq www
deny   ip any any
access-list 101 permit ip 192.168.24.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 110 permit ip host 192.168.24.10 any
access-list 111 permit ip 192.168.24.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 150 deny   ip 192.168.24.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 150 permit ip 192.168.24.0 0.0.0.255 any
snmp-server community public RO 23
route-map STATIC permit 10
match ip address 110 150
scater1983
You need to append a route-map statement to the end of the static xlate. This tells the router not to process the static xlate if sending traffic back to clients across the VPN.
This following configuration should work for you.
ip nat inside source static 192.168.24.14 !!!.!!!.40.69 route-map VPN_2_STATICS
ip access-list extended VPN_2_STATICS
10 deny ip 192.168.24.0 0.0.0.255 192.168.101.0 0.0.0.255
20 permit ip any any
ip route-map VPN_2_STATICS permit 10
match ip address VPN_2_STATICS
Cheers,
scater1983
