Skillsforall Networking acadmy Wireshark
ali-dj
Part 2: Capture and Analyze Local ARP Data in Wireshark
As seen above.  So it says... In Part 2 of this lab, you will ping another PC on the LAN and capture ARP requests and replies in Wireshark. You will also look inside the frames captured for specific information. This analysis should help to clarify how packet headers are used to transport data to their destination.
1. Ping on what platform Command on windows ? or ping on wireshark
2. i have watched a video on youtube and this guy basically pings a IP address and while doing that he types ICMP on wireshark and shows the replies on the ARP requests
Problem here is that my is not doing that at all
Many thanks,
what is the context of your question ? How do we get access to that lab, so we can check what is going on ?
