Slow command output cisco C9300-48U
We have two new cisco C9300-48U. when I ran it up and put one into production, it seemed fine.. but now when I issue the command 'sh auth sess' it takes over a minute to produce output :
camia#sh clock
13:14:15.613 AEDT Fri Feb 9 2018
camia#sh auth sess
Interface MAC Address Method Domain Status Fg Session ID
Gi1/0/2 00e0.db45.9a69 mab DATA Auth 1D1418AC0000012B2C326D3F
Gi1/0/3 00e0.db45.9a79 mab DATA Auth 1D1418AC0000309C783476B8
Gi1/0/1 00e0.db0f.ee68 mab DATA Auth 1D1418AC00002C0F4E9886A4
Gi1/0/4 00e0.db0e.e6e3 mab DATA Auth 1D1418AC000030B178451404
Session count = 4
Key to Session Events Blocked Status Flags:
A - Applying Policy (multi-line status for details)
D - Awaiting Deletion
F - Final Removal in progress
I - Awaiting IIF ID allocation
P - Pushed Session
R - Removing User Profile (multi-line status for details)
U - Applying User Profile (multi-line status for details)
X - Unknown Blocker
camia#sh clock
13:15:35.953 AEDT Fri Feb 9 2018
I'm also seeing this throughout the log
Feb 9 10:29:44.695 AEDT: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 1 R0/0: fman_fp_image: WRClient 0x165c44f3 download to DP failed
Feb 9 10:42:25.707 AEDT: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 1 R0/0: fman_fp_image: WRClient 0x113aa674 download to DP failed
We decided to upgrade to latest version Everest-16.6.2  ED and logs no longer coming but still slow in running the command.
upgraded to 16.2.2
camia#sh ver
Cisco IOS XE Software, Version 16.06.02
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.6.1r [FC1], RELEASE SOFTWARE (P)
and I'm still seeing the issue :
camia#sh clock
09:59:32.542 AEDT Mon Feb 19 2018
camia#sh auth sess
Gi1/0/2                  00e0.db45.9a69 mab     DATA    Auth        1D1418AC00000030A300AEDC
Gi1/0/4                  00e0.db0e.e6e3 mab     DATA    Auth        000000000000000BA300A053
Gi1/0/1                  00e0.db0f.ee68 mab     DATA    Auth        1D1418AC00000032A300B4B7
Gi1/0/3                  00e0.db45.9a79 mab     DATA    Auth        1D1418AC00000035A300BC37
Session count = 4
  P - Pushed Session
  X - Unknown Blocker
camia#sh clock
10:00:38.237 AEDT Mon Feb 19 2018
doing this command also takes a long time
camia#sh auth brief switch active r0
but doing either of these commands :
camia#sh auth sess int g1/0/1
camia#sh auth sess int g1/0/1 detail
is instant.. it just seems to be the enumeration process that seems to take a long time.
Does any one have faced same issue and found resolution ?
Cisco recently released new version Everest-16.6.3  ED (02-Mar-2018). After upgrading to that version issue got fixed. One minute reduced to 2 second to produce output.
Even after upgrade still logs coming...WRClient 0x18d949f8 download to DP failed...Seems hardware is bad...Look forward to see the suggestions...
You're posting this in the UC area of CSC, might want to move this to the switching area to get assistance.
java
if this helps, please rate
Thanks. Look to be posted at wrong place. Created new in R&S section.
