Slow network speed between Primary and Secondary networks
Accretious
Scenario: One 2811 router, handful of Catalyst switches, 2 networks on one ethernet interface.
interface FastEthernet0/0
ip address y.y.250.1 255.255.255.128 secondary
ip address x.x.188.1 255.255.255.0
duplex full
speed 100
no mop enabled
Problem: Workstations in network x.x.188.0 have abysmal transfer speeds with workstations in y.y.250.0 network, and vice versa. We're talking a max of 3mbit when doing speed tests vs 80mbit when the workstations are in the same network.
Switch hooked to router has speed and duplex set to match router.
Any suggestions?
11 Replies 11
Leo Laohoo
duplex full
speed 100
Don't understand why these two lines are there unless your Catalyst switches are the old 2900XL/3500XL.
Can you please post the output to the command "sh int f0/0".  I would also like to see the "sh interface" output to the switch directly connected to the router.
acampbell
What default gateways are being used for each network ?
They should be using indidual gateway addresses of their own subnet ranges
x.x.188.aaa should be using x.x.188.1 and y.y.250.aaa should be using y.y.250.1
Alex
Regards, Alex. Please rate useful posts.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Interface stats show no errors?
3 Mb(it)ps or 3 MB(yte)ps?  3 Mbps is rather low for a 2811.  Although the 2811 doesn't offer 100 Mbps performance, I've gotten as high as about 20 Mbps, duplex.
Is CEF supported and enabled?  If not, route-cache active, including for same interface?
There might be some "odd" about using a secondary address and performance.  Don't know, but you could trunk to the Ethernet interface and define two subinterfaces.
PS:
The higher rate transfer rate, when workstations on the same subnet, makes sense as they can then bypass the router.  The older ISRs are designed for WAN bandwidths even though the have "high speed" LAN interfaces.
Accretious
leolaohoo:
2811_router#sh int fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is x.x.5988 (bia x.x.5988)
  Description: LAN
  Internet address is x.x.188.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 6/255, rxload 4/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1876000 bits/sec, 311 packets/sec
  5 minute output rate 2565000 bits/sec, 328 packets/sec
     1174273172 packets input, 397448584 bytes
     Received 20742715 broadcasts, 735209 runts, 0 giants, 0 throttles
     2292574 input errors, 1557365 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     1229891806 packets output, 3977532888 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
3560_switch#sh int fa0/48
FastEthernet0/48 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is x.x.94b4 (bia x.x.94b4)
     reliability 255/255, txload 3/255, rxload 4/255
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:10, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 63254625
  5 minute input rate 1856000 bits/sec, 246 packets/sec
  5 minute output rate 1323000 bits/sec, 234 packets/sec
     1229948999 packets input, 1135655270681 bytes, 0 no buffer
     Received 1115139 broadcasts (679328 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 679328 multicast, 0 pause input
     1193314482 packets output, 866796695115 bytes, 0 underruns
     0 output errors, 404641 collisions, 1 interface resets
     0 babbles, 1571450 late collision, 0 deferred
acampbell: The correct gateways are being applied.
JosephDoherty: See above output. Looks like there are errors. 3Megabits, not bytes. CEF is enabled.
Judging by the amount of incoming errors you are seeing
Can you post the config of the switchport you are connected to.
If it is hard coded to 100M full duplex I would replace the cable
Alex
interface FastEthernet0/48
switchport mode trunk
duplex full
mls qos trust dscp
auto qos voip trust
macro description cisco-router
spanning-tree portfast trunk
spanning-tree bpduguard enable
As for the cable, that was the first thing I changed, as well as a different interface on the switch.
Your router is NOT a trunk, your switch will be sending tagged frames
I would set this switchport back to being an access port
no switchport mode trunk
no switchport trunk encapsulation dot1q
switchport host
duplex full
speed 100
no spanning-tree portfast trunk
switchport access vlan AAAA --- Replace this with the correct vlan for the router
Alex
Disclaimer
Posting
Besides the number of CRC and runt errors, as noted by Alex, you got quite a few output drops on the 3560 too.  Both are going to degrade your performance.
acambell: Thank you. I will change those settings Friday afternoon so as not to disrupt any users.
JosephDoherty: Is there anything I can do about that?
Disclaimer
Posting
Depends on whether your "too fast" is sustained or transient.  For the former, perhaps not, athough since the 3560 is a L3 switch, you're only using the 2811 for WAN routing, right?
For the latter (transient), buffer tuning might might a difference.  NB: Unsure it can be done if QoS isn't enabled.
Alex and Joseph are both right.
The 3560 has high output drops and this is reflected on the router with high input drops.  Basically the 3560 is pushing at wire speed and the 2800 just can't take it.
Can you try this:  In the router, change the speed to 10 Mbps and clear the counters of the router and the switch.  Observe for 4 hours if both counters increment.  If they don't then you know where the problem is and you have a few options to choose from.
By the way, what is the WAN bandwidth?
