03-12-2007 07:58 AM - edited 03-05-2019 02:50 PM
Hi all,
This is just an general question. We have two subnets on our network. Both these networks are routed. We have Cisco 1721 Router. It has only one Ethernet Module. We cannot user another. It is the gateway for subnet1 and subnet2. subnet2 gateway is defined as secondary. We have several cisco 2950 series switches. All our server are in subnet1.
Now to say, anyone in subnet2 trying to access resourses like servers, network printers which are in subnet1, the responce time is very slow. Like you click on a file to save / print, it takes long time. Whereas users on subnet1 have no problems (since all resources are on same subnet).
I guess we need to either upgrade the router or connect a layer 3 switch.
Is the network on subnet2 experiencing slow response since its gateway is defines as secondary ? I mean to ask, does this effect in any such way ?
Please give some suggestions. Hope am clear.
thanks,
abc.
Solved! Go to Solution.
03-17-2007 08:58 AM
After setting both sides to auto and changing the cables, there are no CRC errors now. Seems the network response was slow due to bad cables. The Switch was showing input/output packets during business hours. And there is considerable difference than before.
R1#sh int fa 0
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 000d.285a.9024 (bia 000d.285a.9024)
Internet address is 192.168.4.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d05h
Input queue: 1/75/364/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 55000 bits/sec, 23 packets/sec
5 minute output rate 60000 bits/sec, 19 packets/sec
11658615 packets input, 2652381494 bytes
Received 387879 broadcasts, 0 runts, 0 giants, 0 throttles
554 input errors, 0 CRC, 0 frame, 554 overrun, 0 ignored
0 watchdog
11108427 packets output, 3065956084 bytes, 2542 underruns
2542 output errors, 0 collisions, 0 interface resets
0 lost carrier, 0 no carrier
Thanks to all of you.
abc.
