Slow VLAN interface response (slow ping)
Jan Rolny
Level 3
Level 3
I would like to ask if anybody has experience with slow response of VLAN interface on L3 switch (3750-X)
I have two pairs of 3750-X switches. Every pair is configured in stack. This two stacks are connected together via 2 TenGigabitEthernet ports and are configured as trunk dot1q.
I created new VLAN on my cisco 3750-X swicth, created new VLAN interface and assigned appropriate IP address. When i try to ping to VLAN interface so I notice little bit slow response (time to time).
Reply from 10.252.20.254: bytes=32 time=1ms TTL=255
Reply from 10.252.20.254: bytes=32 time=36ms TTL=255
Reply from 10.252.20.254: bytes=32 time<1ms TTL=255
Reply from 10.252.20.254: bytes=32 time=3ms TTL=255
Reply from 10.252.20.254: bytes=32 time=28ms TTL=255
Reply from 10.252.20.254: bytes=32 time=6ms TTL=255
Do you think it is normal or is it possible somehow to solve this slow responses? Because if I ping two connected servers in sam VLAN so their response is under 1ms all the time.
So why VLAN interface has sometimes this slow response?
Please se config below:
Current configuration : 17783 bytes
version 12.2
no service pad
no service dhcp
hostname SomeHostName
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
system mtu routing 1500
no ip domain-lookup
ip domain-name some.domain.com
crypto pki trustpoint TP-self-signed-3107166720
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3107166720
revocation-check none
rsakeypair TP-self-signed-3107166720
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet0
ip address 192.168.1.13 255.255.255.0
interface GigabitEthernet1/0/1
switchport access vlan 20
switchport mode access
switchport nonegotiate
no cdp enable
no cdp tlv server-location
no cdp tlv app
interface GigabitEthernet1/0/2
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/3
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/4
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/5
no cdp enable
no cdp tlv app
interface GigabitEthernet1/0/47
switchport access vlan 21
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
switchport trunk allowed vlan 20,21
switchport mode trunk
interface TenGigabitEthernet1/1/2
interface GigabitEthernet2/0/1
no cdp enable
no cdp tlv app
interface GigabitEthernet2/0/2
no cdp enable
no cdp tlv app
interface GigabitEthernet2/0/3
no cdp enable
no cdp tlv app
interface GigabitEthernet2/0/4
no cdp enable
no cdp tlv app
interface GigabitEthernet2/0/5
no cdp enable
no cdp tlv app
interface GigabitEthernet2/0/6
no cdp enable
no cdp tlv app
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 10.252.20.252 255.255.255.0
standby 1 ip 10.252.20.254
standby 1 priority 101
standby 1 preempt
standby 1 track 1 decrement 10
interface Vlan21
ip address 10.252.21.252 255.255.255.0
standby 1 ip 10.252.21.254
standby 1 preempt
standby 1 track 2 decrement 10
no ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
login local
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
line vty 5 15
login
end
Thank you for your help :-)
Jan.
Hi Jan,
As mentioned above, there is no issue with the cpu at 21% and the Hulc LED Process taking around 10% of the cpu is normal.
You can check if you hit the following bug:
CSCsi78581 Hulc LED Process uses 10-15% CPU on Catalyst 3750/3560.
Symptom:
CPU utilization for Hulc LED Process of around 10-15% is seen on Cisco Catalyst 3750 and 3560 switches, even with no ports connected. show process cpu shows higher than expected CPU utilzation.
Conditions:
This issue may be seen on a Catalyst 3750 or 3560 switch, typically with no ports connected.
Workaround:
None.This is a minor issue and does not affect the hardware forwarding performance of the switch.
Unless you see an impact on the network, you need not worry about the ping response and cpu level of the switch.
Hope that helps.
Cheers,
Abhishek.
9 Replies 9
abhischa
Hi Jan,
So i understand that you are seeing slow ping responses when you initiate pings to the newly created vlan. I would like to inform you that if there is no current indication of any problem on the network, an intermittent increase in ping response is expected as ICMP is treated as low priority. Many more-important tasks have precedence over ping response generation. Therefore, ping response times (average) of 7-10 ms are typical, even on a completely idle switch. On a particularly busy switch, response times can be even longer.
Does that answer your question? What is the average ping response time that you see? I do not see the ping response output that you have attached causing any issues on the switch / network.
Hope that helps!
Cheers,
Abhishek.
Hi Abhishek,
thank you for reply. Yes it partly answers my question. Regarding CPU load on the switches, there is also little bit bigger load than expected.
Also there is still no big traffic. New servers are just connected to switches but most of them are not configuerd yet.
So it is confuses me.
No traffic = 21 percent CPU load (no traffic means, just DHCP Discover transaction and HSRP hello packet and STP protocol )
and
No traffic = average 3ms ping response from 500 ping's.
So do you thing that it is normal behavior of 3750 switches?
Thank's in advance.
Jan.
Hi Jan,
A ping response average of 3 ms is not something you should worry about. Regarding the cpu, 21% is not high. Please attach the output of 'show proc cpu sorted | e 0.00%' so that we can see which process is causing the cpu to be at 21%.
Cheers,
Abhishek.
Hi abhischa,
sorry for late answer here is show process cpu sorted. it is not complete but it is sorted so highest utilization is up. As you can notice so Hulc LED Process is taking  most of CPU time. What I do not understand again :-) Is it possible that it is because server machines are not installed yet so their network adapters go up and down again and again because machies reboot if system is not found, and it take CPU time on switch?
What is true, that in log is many messages about ifdown and ifup and also LED's go to orange and green color very frequently.
CPU utilization for five seconds: 25%/0%; one minute: 24%; five minutes: 23%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
139       78657     14470       5435  7.98% 10.14%  9.94%   0 Hulc LED Process
  67       22048      3758       5866  2.87%  2.80%  2.50%   0 RedEarth Tx Mana
106       11359      1381       8225  1.75%  1.65%  1.45%   0 hpm counter proc
   8        1012        13      77846  1.75%  0.21%  0.12%   0 Licensing Auto U
232        9297     36025        258  1.43%  1.44%  1.10%   0 HSRP Common
  87        2497     18271        136  1.43%  0.74%  0.36%   0 HLFM address lea
145         530       291       1821  1.11%  0.31%  0.12%   1 SSH Process
180         192      1287        149  0.31%  0.07%  0.01%   0 IP ARP Track
149        2291       177      12943  0.31%  0.31%  0.30%   0 HQM Stack Proces
  89         505     18409         27  0.15%  0.11%  0.04%   0 HLFM address ret
150         853       518       1646  0.15%  0.15%  0.12%   0 HRPC qos request
  66        1047      5678        184  0.15%  0.11%  0.11%   0 RedEarth I2C dri
  86          32       519         61  0.15%  0.01%  0.00%   0 HRPC hlfm reques
178         339      2811        120  0.15%  0.05%  0.02%   0 IP Input
192         426      1470        289  0.15%  0.03%  0.03%   0 Spanning Tree
  78         325      3249        100  0.15%  0.04%  0.00%   0 yeti2_emac_proce
  16           0        14          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  17           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  15           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  20           0       792          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  18           0       792          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19           0         7          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  23           0         3          0  0.00%  0.00%  0.00%   0 PrstVbl
  24           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  14          59        13       4538  0.00%  0.00%  0.00%   0 Entity MIB API
  26           0         1          0  0.00%  0.00%  0.00%   0 License IPC serv
  27           0       665          0  0.00%  0.00%  0.00%   0 GraphIt
  21           8        27        296  0.00%  0.00%  0.00%   0 IPC Seat Manager
  22           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  13           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  31           0       792          0  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  32           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  33         183      1410        129  0.00%  0.01%  0.00%   0 Net Background
  34           0         1          0  0.00%  0.00%  0.00%   0 IDB Work
  35          17       262         64  0.00%  0.00%  0.00%   0 Logger
  36           0       661          0  0.00%  0.00%  0.00%   0 TTY Background
  25           0         3          0  0.00%  0.00%  0.00%   0 License IPC stat
  12           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  39          16         8       2000  0.00%  0.00%  0.00%   0 IF-MGR control p
  40           0       183          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  41           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  42           0        12          0  0.00%  0.00%  0.00%   0 Net Input
  43          48       136        352  0.00%  0.00%  0.00%   0 Compute load avg
Thank you very much.
Jan.
Hi Jan,
The CPU utilisation on the switch is absolutlely fine.
The HULC LED process it takes around 15-20 % CPU is perfectly normal , that is a known issue with teh 3750 sesries swicthes.
From the output there is no particular process which is taking large CPU cycles.
Rebooting of devices connected to the switches doesnt have anything to do with CPU cycles .
The CPU utilisation of around 50 % and above is considered as high , below than that you dont need to worry.
Please rate helpful posts
Swati
Hulc LED process usage for this platform is perfectly normal. I would be worrying if you saw it any more than what you are seeing now (typlically at around 50% or so).
Hi Jan,
Symptom:
Conditions:
Workaround:
Hope that helps.
Cheers,
Abhishek.
Hi Abhishek,
thank you for investigation. Seems it is really bug, what can very confuse customers. From my point of view it should not happen.
Cheers,
Jan.
Yes Jan, i understand your concern. Unfortunately a few bugs do exist in all forms of code. Luckily for us we were able to find out the bug that we were hitting:)
Cheers
-Abhishek.
